Ok here is the update, I powered down the solar and the inverter, and disconnected the battery + from the SCC, at the time of disconnection it was getting 1 watt and 18.7 volts DC with full sun on the panel. here is what happened next.
Action: I added a heavy gauge wire to the Battery - of the SCC, I then terminated that wire at the shunt that has the negative run from the outside batteries, I terminated it on the same side as the positive that goes to the Battery + on the SCC just for uniform sake. I powered the system back up, and replaced the main solar fuse.
Result: As soon as the solar panel came online i was seeing 30-40-50 all the way to 98 watts coming from the panel at 33 volts DC, the battery was also showing a charge output of 6.7-8.3 amps
Action: I went up top and unhooked the "helper panel" from the chain so just the 320 trina would be running, I went back down stairs.
Result: No change in the readings
Action: I unhooked the solar and the battery from the SCC for 10 minutes, and then hooked up first the battery and then the solar as soon as the system was reset
Result: as soon as the solar came online i was seeing a max of 115 watts and 36.0 volts coming from the panel, the charging amps had changed a little but not much
Action: I went up top and disconnected the splitters and had just the trina running directly from the panel to the SCC
Result: no real change in the readings, but a problem did develop (more on that later)
Action: I went up top and washed and dried the panels, they had scum on them, and then once they were shiny i came back downstairs
Result: no change in the reading
All throughout this process the controller has STAYED in MPPT and not moved to any other mode, Also while fiddling with the wires I noticed drew had put one on way to tight and it slipped outof its MC4 connector, I have rigged it for now, but that whole run will need to be redone, I am thinking of just ordering a 50 foot kit and redoing it myself, I can get a 50 foot kit of pos-neg MC4 preterminated cables for about 30 bucks at home depot (their not in stock go figure so ill have to order) or Amazon. This would require me reopening the roof grommet to run the new wires, but it might be an improvement.
I am going to hook the PWM controller just for giggles and I do not plan on returning it, for its obvious the issue was drews negligence in not hooking up the NEGATIVE CABLE in the very first place, and Ill never even know if those batteries ever charged at all, and if they did HOW????? I would love for someone to chime in on that.
Truth be told having an extra controller around as a spare is not that bad, and it was only 25 bucks,
Result: its obvious now the batteries are charging, maybe not at 30amps, but lets see what the PWM controller brings us.
Should I invest in an MC4 termination kit, since I may need it again in the future (about 150 bucks) or just get the pre terminated stuff now?
Also why only 115 watts out of a 320 watt trina????? I know I need to account for loss, but that is ridiculous
Ok ill await the replys, thanks again for your patience everyone, were sniffing this thing out finally!
