Looking for a good 24V 3000W Inverter/Charger for Offgrid Solar System?
  • NochiLife
    • Jun 2019
    • 63
    Originally posted by solardreamer
    Thanks for the doc. It would be great if you could post the config string.
    The config string will vary depending on the inverter make/model. You can read the config string out and save it somewhere so you know how to "repair it" if necessary.
    Here's a screenshot I took of a "serial port bridge" (utilizing a Parallax Propeller with a VGA "video driver"--actually on an older touchscreen LCD computer monitor) showing communication between the TS-3000 and the PC software (for "hacking" the protocol):
    Blue is the TS-3000. Red is the PC software. You can see the "Q" command for reading status, the "I" command for reading configuration, and the "W" command for writing configuration.
    I noticed the "Download" countdown, but do not have any documentation for how that is intended to work.
    Going from Mean Well to Power Jack seems like quite a few steps down. I am guess you really wanted surge power but went with HF inverter for cost reasons which is ultimately a losing proposition. If weight wasn't an issue I would also go with LF inverters. I only have experience with Mean Well power supplies which has been good. The TN/TS inverters look to be better/more reliable than the typical HF inverters (Chinese and non-Chinese) that are little time bombs by design.
    Yes, the MeanWell HF inverters are quite good for their price range and topology (HF inverters). My only complaints with the MeanWell were:
    • Could not adjust the OVP shutdown to 60v (as I thought I should be able to from the datasheet). Fine if you're using Lithium-based batteries--but if you're using lead-acid with temperature compensation, you're out of luck.
    • No-load current was a solid 1A at 48-60v. (That's at least double what a 6kw LF Genetry Solar inverter runs at no load.) Notice that this specification is not listed in any of the documentation--they only list the "power save" draw, which is with the inverter basically off.
    • Maximum efficiency of 91% listed is not significantly greater than a good LF inverter (=85%+)
    • Couldn't start a window A/C unit--I have video of this. Didn't blow up though.
    It is also worth noting that you have to periodically open the MeanWell inverter up and clean all the dust out of it. If you do, it should live for years and years to come.
    If you don't, you'll end up with this:
    (screenshot from a chat with the guy I sold my MeanWell to, a year or 2 later...he'd bought a second one shortly after buying the one I had, and I have no idea which one bit the dust here!)
    The inverter in question here hit the dumpster before I was aware of it; I'd have been curious to see what exactly went wrong with it.
    I have seen a few of the GS inverter videos. Assuming you are the one doing the testing in the explosion videos, it's quite impressive what you have done. You should have started from scratch from the beginning then trying to fix Power Jack designs. It's great that you are offering nice alternatives between the junk LF inverters and the Cadillac LF inverters. It's interesting to see big central A/C's running off-grid but I do wonder if that's really a common scenario for full time off-grid people. I would be interested if you ever make an HF inverter.
    More people than you think want to run A/Cs on their off-grid systems. It's actually a very common question--well, when you think about it, most people want to "live like normal on solar", instead of stripping down their requirements to the bare minimum.
    I'm the "Sid" in said videos...yeah, the explosions were definitely unnerving (sounds like a gun going off when all that power gets misdirected in the FETs)...but we did get it solved.
    Yes, it could be said that starting from scratch could be better--BUT if I can redesign based off an existing design, then I don't completely have to "reinvent the wheel." As of right now, the next batch of GS inverters will not use a single PJ board--every single board in the inverter will have been designed on my desk, with all specification design requirements determined in the same place.
    Worth noting: the no-load current of the GS 12kw inverter prototype seen in said videos...is significantly LOWER than that of the 3kw Mean Well TS-3000 (0.7-0.8A vs 1.0A). Just sayin'
    As of right now, I have zero plans to make an HF inverter...because their surge capacity is extremely low (due to designing the boost converter for the stated redline output and no further)...and the output FETs / IGBTs don't have any "protection" against dirty loads / backfeed. Adding to that, HF inverters have to have a completely separate "Battery charge" circuit--I am not aware of any HF inverter that can use the existing "inverter" circuitry in reverse to charge the battery. LF inverters are considerably more versatile in design by that regard, as no extra circuitry has to be added for battery charge. LF inverters can also (if properly designed/programmed!) easily handle grid-tie solar arrays, using excess power from them to charge the batteries, and shutting the grid-ties down when the batteries are full, etc.
    • NochiLife
      • Jun 2019
      • 63
      Third reason against HF inverters....they have a very hard time handling split-phase 240vAC, which is kinda a requirement for powering a small house these days. Some manufacturers handle this by putting 2 identical HF inverter units in the same chassis, synced 180 degrees apart. Others require you to purchase an autotransformer--which reduces the system efficiency, adds weight, etc., etc., and you're basically right back where you'd be better off with an LF inverter.
      LF inverters also handle phase imbalance considerably better (HF inverters even if designed for split-phase output will really complain if the load is imbalanced.)
      To each their own though .
      • solardreamer
        • 465
        Thanks for the info. It's quite helpful.
        The low OVP appears to be the most common complaint I have seen for Mean Well inverters. Fortunately, I use LFP batteries so that's not an issue for me. As for no load current, lower is generally better provided it does not mean degrading other important inverter attributes (performance, durability, quality, etc.). So, it's not really a valid comparison unless other key attributes are similar. For example, I have seen various barebone HF inverters with ~0.25A no load current but they don't have the snubbers to protect against transients necessary to ensure long inverter lifespan, inadequate capacitance to support high loads without significant waveform distortions and little or no output filtering to ensure low EMI and low voltage and current THD.
        I was thinking permanently off-grid people would still have A/C but perhaps more energy/power efficient ones (e.g. variable speed heat pumps, mini-splits, etc.) rather than a traditional big central A/C that requires huge surge power to start.
        It's great to see GS inverters moving away from PJ. PJ inverters are amazingly cheap but amazingly bad too. I wonder if they make more money from selling new inverters or repair parts for failed inverters.
        To me, HF and LF inverters have different target use cases. As I mentioned before, I would use LF inverters if weight wasn't an issue. LF inverters can certainly do many things but that doesn't mean HF inverters can't do the same. Check out the Cotek SC series which is a bidirectional inverter/charger and has the ability to load share with a grid or generator AC input. Also, as you may know, many of the solar hybrid inverters are based on HF topologies.
        • solardreamer
          • 465
          Sure but until you can give me an LF inverter that weighs less than 30 lbs it's not a good fit for my use case
          BTW, for stacking/paralleling capable HF inverter example, check out the Cotek SD series. You can parallel them for current sharing or stack them with appropriate phase shifts for split-phase or 3-phase power.
          • wazoo
            • May 2022
            Hi all
            Recently I have buyed a Meanwell TS-700-248 inverter to replace my burnt Victron 800.
            Is it normal that this meanwell inverters to produce an appreciable switching noise ??
            My old Victron was so silence, just only when fan rotate, but this meanwell looks 10 and 20khz noise spikes under audio spectrum analyzer, and fan is always running....start....stop...start...stop every 10sec, even with low load.
            It looks a poor design nowadays, because expected switching noise was solved , at least for small power inverters,
            thankU NochiLife for sharing meanwell protocol, will help me to monitor mine
