Hi all, and thanks in advance for any suggestions,
I'm building an outdoor solar/battery box to power a Christmas tree that floats on a raft on my town's pond. It'll be 3 @ 100 watt panels charging 2 deep cycle batteries.
It will be cold (in open, in Mass), and I gather cold is the enemy of battery efficiency. It will only be used for two months in the winter, from Thanksgiving to the feast of the Epiphany.
So, the questions are four:
1 - How should I insulate the box? I've seen bubble wrap mentioned, and regular household insulation. I also wondered about using sand. Thoughts? Suggestions?
2 - How much air space I need to leave above the batteries - 2 inches do it?
3 - Would be useful/OK to placed the inverter _below_ the batteries? It seems they give off heat which is an issue in the summer but I'm wondering if I can harness that for my benefit in the winter.
4 - I've seen mention of needing to vent the battery box, but I can't find guidance on how much venting is needed and I'm kinda wondering if I really need to drill holes in the box which will let heat out/cold in. It won't be absolutely airtight, so I'm kinda wondering if it's really needed since most of the guidance I've read is mainly talking about safety for inside-the-home setups.
Thanks for any thoughts,
b
