solar system for shed
I’ve just read that under load and no load the cutoff is different. I swear solar systems are the most confusing thing I’ve ever experienced.
no load or load I try and stop at 12v I hope that’s good enough.12v 150watt, 80ah battery, 75 watt inverter.Comment
Should I fuse my solar panel to cc? I’m getting different opinions here. I’m re wiring my system and was wondering if I can get rid of that fuse?
i have a single 12v 150watt panel running to my cc.
someone told me fuse all positives and other say only fuse panels when you have more than one.12v 150watt, 80ah battery, 75 watt inverter.Comment
someone told me fuse all positives and other say only fuse panels when you have more than one.Comment
Thank you for the quick response I’m doing everything right now.12v 150watt, 80ah battery, 75 watt inverter.Comment
I like to suggest using a circuit breaker, instead of a fuse, It makes diagnosing easier, and can save the hassle of disconnecting the PV from the controller when booting the controller up,
Ya I’m going to put one there and before the fuse box.12v 150watt, 80ah battery, 75 watt inverter.Comment
Anybody have any insight about charging cordless batteries with a inverter? I’m using a modified sign wave inverter to charge me dewalt 20v lithium batteries and just wanted to make sure I’m not messing anything up.
I’ve also emailed dewalt to see what they say but again the opinions on the internet are mixed.
i know they make a 12v charger and I have it but also have another charger plugged into my inverter.12v 150watt, 80ah battery, 75 watt inverter.Comment
You must make the sacrifice to the Modified Sine Gods. Plug it in, and see if it works or dies. The $39 inverter won't die, the $120 charger will, maybePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I’ve used it a few times already and then I started reading about it so I stopped using it. Both times I charged it the batteries worked but now I’m a bit scared. I wanted to see if anybody had anything to say in this forum. I’ll wait until dewalt tells me if it’s ok or not.12v 150watt, 80ah battery, 75 watt inverter.Comment
DeWalt has to say NO. Their gear is certified for 120VAC pure sinewave.
Small light weight chargers use a switchmode power supply, and generally are OK with mod-sine
Heavy chargers with an internal transformer, or a heavy wall wart charger, don't do well with mod-sine, they heat up quite warm.
My guess is if the charger has been used and didn't seem overly hot, it's passed the smoke test and would be ok. I would not leave it plugged in when not actively charging,Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I wrecked a bunch of Makita batteries using a Mod sine wave inverter many years ago. Nowadays, I still wont try it again.Replacement batteries for cordless power tools are way to costly to risk.
2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Ya it’s a 50/50 and I don’t like those odds. One of my batteries is acting funny which got me to start looking into this so I just stopped.
when I go to the shed and the battery is at 14.2 volts it’s still pulling 0.2-0.3amps to the battery and 0.0-0.1 amps to my loads. Is this normal? Should I find out what is taking 0.1amps and put it on a switch to disconnect it while I’m not in there? I believe it’s my car radio but I hav to pulled any fuses yet to see what it is.12v 150watt, 80ah battery, 75 watt inverter.Comment
Dewalt actually said it’s ok to do it. Their recommendation is to use at least a 400 watt pure sign wave inverter.
anybody have any input on my above question?12v 150watt, 80ah battery, 75 watt inverter.Comment
Just for fun, if I want to upgrade to 400 watts and run 12v appliances what would you guys suggest.
2 200 watt 12v panels
or
1 400 watt 24v panel with a 12v converter right before the fuse box.12v 150watt, 80ah battery, 75 watt inverter.Comment
