Small off grid solar usb charging station system.
  • AllOuT
    • Mar 2018
    • 12
    Okay, that's understandable, I didn't jump the gun with buying anything. Its not that I want an overkill system, I want a system with what I could charge my devices and have a decent amount of power to spare, in case of bad weather, I live in eastern europe in Latvia, we have 4.8 sun hours, I don't know if that's a lot or not but its 5th best for northern europe. Weather in Latvia, especially in the summer and autumn is a lot better than England's
    I'm happy that a small panel will do, I was doing these solar calculators which insisted I used big batteries and solar panels, I'm glad I asked real people not calculators.
    I still don't understand, if all of the device batteries combined are 30ah, how will a 15ah battery be sufficient enough to charge them in one go?
    Sorry if my questions are dumb, its just that a week before I didn't know anything about solar panels or batteries, still learning.
    So I need 34wh a day, to be generated, to charge my devices every 5th day, I'd like some energy to spare, just in case as I mentioned.
    I've seen people on youtube, and calculators insist that you need a twice bigger battery than your need to charge your load with, with not letting your battery discharge more than 50% you increase its life span dramatically, should I then require an 30ah battery not a 15ah?
    Added pictures of every part along with its specs below, please tell me if something is off, and your suggestions on what could be changed, and which charge controller should be chosen.
    Thanks for the advice, I'll be impatiently waiting for your response.
    AGM 17Ah 20HR 12V - Deep Cycle Solar Battery specs:
    System Voltage 12V DC
    Storage Capacity (Ah) 17Ah
    Capacity at HR1 (C1) 11,1 Ah (11.1A,1.75V)
    Capacity at HR5 (C20) 14,5 Ah (2.9A,1.75V)
    Capacity at HR10 (C10) 16,5 Ah (1.65A,1.75V)
    Capacity at HR20 (C20) 17 Ah (0.85A,1.75V)
    Self-Discharge max. 3% (per month / 25 C)
    Charging Current max. 5,1A
    Load Shedding (no-load) 13,6V-13,8V (-20mV/ C)
    Charging Voltage (cyclical use) 14,4V-15V (-30mV/ C)
    30w mono 12v solar panel specs:
    System Voltage 12 V
    Generator Performance (Wp) 30 Wp
    Module Voltage (Vmp) 17,8 V
    Max. Current (Imp) 1,69 A
    No-Load Voltage (Voc) 21,3 V
    Short-Circuit Current (ISC) 1,82 A
    max. System power (V) 600 V
    Cell Type monocrystal
    Degree of Efficiency Cell >18%
    Tolerance +/- 3%
    Temperatur Coefficiency -0,45% / C
    Inverter: HF12-300 12V 300W 600W voltage transformer modified sine wave
    Charge controller:
    Charge Controller Type PWM
    System Voltage 12V DC, 24V DC
    Charging Current (A) 8A
    Deep Cycle Protection 11,2V-11,6V (22,4V-23,2V)
    Connection Clamps 4mm2 / 6mm2 - AWG 12 / 9 (fine- / single wire)
    Protection IP IP32
    Restart Voltage 12,4V - 12,7V (24,8V-25,4V)
    Charging Voltage 13,9V (27,8V)
    Boost Charging Voltage 14,4V (28,8V)
    Self-Consumption Under Load < 4mA
    Load Current max. 8A
    The only difference between the 8A controller and the 6A was:
    Load current max: 6A
    No-load voltage solar module < 47V
    The load:
    Input: AC100 ~ 240, 50 ~ 60Hz
    Output: DC12V / 2A
    P.S If pictures of products aren't allowed, I'll have no issue of them being removed, or being asked to remove them.
      That sounds like a yearly average which is used for Grid Tied Systems, not Battery systems. Off grid is designed to worse case Winter Sun Hours. If you look for late December early January I bet it is around 2 to 3 hours, and summer is up around 5 to 6 sun hours.
      Because you made the mistake of using AH. You use Watt Hours. Example a 3.6 volt 3.5 AH battery has a wh capacity of 3.6 volts x 3.5 AH = 12.6 watt hours. For a 12 volt battery is 12.6 wh / 12 volts = 1 .05 AH just call it 1 AH.
      Your first big mistake, quit watching You Tube. You only got it half right from watching morons on You Tube. True you do not want to take your battery down to more than 50% normally. Problem is what do you do when you get cloudy days. With that logic you go dark after 1 cloudy day and shorten battery life discharging 50% every day, and have to wait for a couple of days to recharge.
      The right way is determine how many watt hours you need in a day. Say it is 100 wh. You size the battery for 5 day capacity so you only use 20% on any given day, So 5 x 100 wh = 500 watt hours. So what is the AH? Well at 12 volts is 500 wh / 12 volts = 42 AH. That gives you 3 days run time with cloudy days before you have to shut down and recharge. Additionally any true off-grid system requires a generator for those times when you get a week or two of cloudy days, and perform monthly battery maintenance. At 20% DOD daily triples your battery life.
      You Tube idiots. Imagine if pilots learned to fly using You Tube. You would stil have to use a ship to come to the USA.
      Not so fast. I am not going to tell you. You are going to tell me. Not trying to be a dick, but I want you to learn and quit watching youtube. Read this sticky and come back and tell me what you are going to do. Then I will give you feed back. Here it is in a nutshell.
      1. Determine daily Watt Hours
      2. Determine battery voltage. (hint 12 volts)
      3. Determine Battery AH capacity. [Daily wh x 5] / Battery Voltage = AH
      4. Determine charge current and charge controller size. (Hint C/10)
      5. Determine Panel Wattage required. If PWM panel current = charge current
      Your turn, go do your homework and come back with answers.
      • AllOuT
        • Mar 2018
        • 12
        Hi, thanks for making it as a task, I had a great time finding the answers.
        1. So the daily watt hours should be 30wh because I would use 150wh every 5th day.
        2. The battery would be 12V because I for sure will need one small panel, due to to the small daily watt hour requirement.
        3. From my calculations I only need a 12.5AH battery, but I'd prefer to size up, not down for energy storage, to a 17AH battery.
        4. The charge current would be 1.7A, which means I can have a very small charge controller, but I'll take this 6A since its from the same website as the rest of the components, and has good reviews.
        5. Required panel has to be at least 15w, but I'd prefer to get the 30w one. The charge controller will be PWM, so the panel current = 1.7A? It says max 1.69A on the 30w panel though.
        Does that mean that a 17AH is too big for a 30w panel?
        If I ever get suddenly rich is it a good idea to get a lithium-ion battery?
        Thanks for the good advice.
          1. So the daily watt hours should be 30wh because I would use 150wh every 5th day..
          OK are you telling me every 5 days you will will be taking 150 wh from the battery all at once?
          Need to know to give you an intelligent answer.
          • jies1
            • Apr 2018
            • 6
            I registered to ask this question, but once registered i couldn't create a topic. What i am wanting to do is to put a 12 volt battery in my deer stand, so that my children can watch an ipad pro and charge it while watching. other than that i may charge a cell phone once in a blue moon. also i wanted to run 2 small 12 volt lights in my deer stand for when its dark and im working on firearms or etc. i intend for the bulbs to be green so that they do not bother the animals. can anyone tell me what equipment i need or point me to a specific list of products that i need. i don't want to spend more than i need to. if anyone is willing to help please pm me.
              • 15205
              You have now been approved by our Admin so you should be able to create your own thread.
              • AllOuT
                • Mar 2018
                • 12
                Yes, that would be the idea, maybe not all of the 150wh but more or less, maybe around 80-130wh. I also forgot to mention that the usb charger itself is 40w, but then rounding up the battery 17ah and panel to 30w, it doesn't really matter. I'm not sure for how long I would charge these devices, they all have varying battery capacities.
                  OK now that you have a better understanding of what is going on, and I know what you want to do exactly if it were me this is what I would do.
                  Panel Wattage = 40 to 50 watts
                  PWM Charge Controller minimum = 5 amps
                  12 volt battery capacity = 20 AH
                  The reason it is a little larger than you might be expecting is because of hitting the battery with 150 wh in one singe day. Normally you would limit daily discharge to 20%, but in your case once a week we can push that up to 60 to 70%. So 150 wh / .7 = 215 wh/12 volts = 18 AH plus some wiggle room.
                  Panel wattage required is just a straight 2 amps x 18 volts = 36 watts. So for the panel look at the Imp and Vmp spec. A 12 volt battery panel Vmp will always be 17 to 18 volts, so zero in on Imp and look for 2 amps or as close as you can get. That is going to be a 40 to 50 watt range. No less than 2 amps, no greater than 3 amps.
                  As for the controller 5 amp minimum is because I do not think you can find a smaller one than 5 amps. It is not critical as it could be 100 amps, just as long as it is not less than the panel Imp.
                  Understand everything I just went through? When not in use disconnect the USB charger. Otherwise it just drains the system.
                  • AllOuT
                    • Mar 2018
                    • 12
                    Understood, the usb hub has an on off switch, I don't think it would drain power even switched off, do you think it would still drain power while switched off? Ohh, and when assembling the system, I should connect the inverter to the charge controller, then the panels and then the battery? Or is there no difference in what order I make it? (Got it off youtube before you told me that youtube is useless).
                    If I'm getting the same type of batteries, is combining a 17ah one with a 3.2ah a good idea? There just aren't any 20ah ones.
                      I would think so.
                      Always Battery first to Controller, Panels to Controller, then Inverter to Battery . Reverse when disconnecting; Inverter > Panels > Batteries last.
                      You raised a Red Flag. What Inverter? Houston we might have a problem.
                      Do not mix batteries. If no 20 AH move up to as high as 25 AH. 17 AH is cutting it close.
                      • AllOuT
                        • Mar 2018
                        • 12
                        Well, to plug in the power supply of the usb hub charger. Its the same inverter I added the picture of before, its the smallest inverter there is, its description says it's rated for 12V battery voltage, 230V AC output voltage 300W of continuous power and 600W short-term peak performance for high starting currents.
                        Specs say: 220V 230V high frequency inverters with Modified Sine Wave, 300W of continuous power and 5V 2.1A USB load output.
                        I assumed it wouldn't take up much power? Does it? About the battery, maybe I could use two 12ah batteries, identical models? That would make a nice 24ah. Is there an alternative to the inverter? 4403_1000x1000.jpg
