Hello, tried to make sense of what I need myself, but I cant seem understand how big of a solar panel I need, battery size, or if I can actually use solar for this purpose.
I want to make an off-grid USB charging station with a solar panel, preferably with one panel, I have 6 devices that have a total battery capacity of 30000 mah (2500 mah to spare), are there charge controllers that have at least 4 USB ports in them? I would assume if I would charge my load from the controller directly, I wouldn't need an inverter? Otherwise the charging station is a 40w load, I would assume it's more the more devices you charge. I have no clue of how long these devices would charge, I know the USB charger is rated at 5v/2.4A
The purpose of this system would be in a grid-down situation, I wouldn't use this daily, but assuming once the grid is down, I would use the system once every 5th or 6th day, I don't mind keeping the system up, but I'd prefer maintenance-free batteries. I have 4.8 sun hours where I live.
My question is, what's the most cost-effective way to make this system, does the fact that I would only use the system for USB charging change the battery capacity or panel size? Is solar even a choice if I would use this system weekly, not daily? Note: I am on a tight budget (I'm a student), I would like to spend no more than 250$ for the whole system (except the load).
Sorry if there's dumb questions, I'm pretty new to solar, and batteries and such.
I appreciate all answers, and thank you for your time.
