Hi guys,
Iv been doing some research and i will be building a mobile power station,
here are some specs
500 watt of PV
9480 Watts of battery storage, wanting to use half of this
4x 395 ah 6V 395AH (CR395) Supreme batterys costing me $220 AUD each
please tell me if this is a bad or good choice, for below
Charge controller
Brand = Midnight
model = Clasic 150
i need it to have internet connectivity so i can monitor it remotely and on site
All of this will be in the back of a VAN, so i can drive to my property's to do stuff around my yard,
The biggest application it will be using it a leaf blower/mulcher, on the packet they are 2000 watts and 2500 watts getting a watt meter to actually test is power consumption while chopping wood, so i was thinking of getting a 4000 watt puresinewave inverter that would also be monitored via IP, have not found one yet, any suggestions, just enough to cover the devices above mentioned and small items that will need charging,
I plan on using 50% of my battery capacity each day so my solar panels wont cover my power resulting in me needing to charge via mains, Am i able to connect a DC connection directly to the charge controller ? DC outlet at 24 volts 40 amps or what ever the charge controller is rated @ ? or will i need to buy a seperate charging device here?
Thank you very much!
here are some specs
500 watt of PV
Charge controller
Brand = Midnight
model = Clasic 150
