Hi all! First post here. So appreciate all the knowledge and experience I've already seen on this forum! As a newbie to solar tech, resources like this are invaluable. Did a bit of digging for this topic and didn't see quite what I was looking for, so here goes:
I am building a 24V (25.6V nominal technically) solar system with 4x 295W monocrystaline panels (in 2s2p orientation), 8x 100Ah CALB CA100 LiFePO4 cells in series (bottom balanced at 2.75 and looking nicely balanced even towards the top), a 60A MPPT charge controller. Inverter is where I'm a bit stuck.
i originally bought a Go Power 2000W inverter (GP-SW2000-24). Everything was looking swell until I observed the low voltage shutoff behavior. Manual says 21V cutoff, but I saw my beautiful CALB cells dip just below 2.5 (#DangerZone) by the time the inverter shutoff. Fortunately cells look fine, and I've brought them back up and been monitoring them.
When I realized I couldn't adjust this shutoff value I returned this otherwise beautiful inverter after checking with their tech support about options. Sadly I've discovered a customizable low voltage shutoff is a rare feature.
So, after research I realize that many of these inverters were engineered for lead-acid chemistries (i think), so here's the question:
what would be an invertee I could buy that supports 60Hz 120V output (for US standards), that is 24V, supports at least a 2kW load, and has a customizable low voltage shutoff (to support lithium iron phosphate chemistry)?
and if this isn't feasible where can I acquire an LVD relay thingy that support 100A and shutoff voltage around around 24V? (cause searching has yielded little results)
Thanks so much in advance!!
- Chris
- Chris
 Super open to consult with a pro, so if you know any folks near Portland, OR you'd recommend, let me know.
