Hey guys, cabin solar is going very well - Thanks to SunKing and Mike90250 and everyone else for your help. Only remaining (and very annoying) issue is when my fridge starts up, the inverter screams, coughs a few times so all my LED lighting turns on and off a few times, and then eventually everything is OK.
Some more information: Inverter is a 1000W pure sine wave. 2 X 100Ahr FLA batteries. Fridge is a modified chest freezer (installed a bulb thermostat so I can set to 38F or so). KillaWatt mater reads about 90-100W while it is running, but it isn't fast enough to show me whats going on during the startup cycle.
As I said, everything else in the cabin is great, but the fridge (compressor?) must be putting a helluva drag on the inverter. I understand that startup for the compressor will be a lot but the peak for the inverter is supposedly 1500 or 2000W I forget. I tried another inverter (thanks to Costco's return policy) I bought a 1500W inverter with a 3000W peak in hopes of ruling that out. That particular inverter just shut down completely when the fridge came on. C'mon, I find it very hard to believe that this little chest fridge is pulling THAAAAT much power at startup.
But oh well, maybe it is. My solution for the past year or so has been to put the fridge on a timer so that at night it shuts down and at least lets us sleep.
Question: Is there such a device that would somehow slow down the huge startup current that the fridge compressor is pulling, and calm it down or somehow spread it out over a few seconds? Before I just disable the beeper on the inverter I thought I would check with you guys
Does anyone else have a fridge or freezer on solar, and does the startup cause problems?
thanks guys
thanks guys
