Hello everyone, great forum and I have enjoyed reading it for system design info.
Let me start by saying that electric grid from the power company is simply not an option where I am located.
The system below will be full time use, connected to ultra efficient 200 sq ft cabin. Lights are LED, 24 Volt DC chest fridge, DC shower pressure pump, tiny AC washing machine with pulse motor, DC electric teapot, 2 laptops, wifi router and last mile internet equipment are pretty much all our electronics. In the fall we also run a Sedona dehydrator, and I plan to add movie projector in the future (most efficient I can find). Lets say total ~3000 watt hours per day of electric used.
Equipment:
12 x Canada Solar CS6P-235 235 Watt 24 Volt, Vmp 29.8. Imp 7.9A, Voc 36.9 Isc 8.46A
Outback MX60 CC
Outback FlexMax 80 CC
Magnum 4024 24 volt inverter (I know that 4000W is too big inverter for 24volt battery bank, don't plan to ever use it to it's full rating)
2 x Windmax 24v Y-400 Watt turbines, one on 20ft tower, one on 60ft tower
24 Volt forklift battery
I'm planning to set it up like this:
6 x 235 Panels on MX60 CC
6 x 235 Panels on FM80 CC
Both wind turbines connected directly to the battery with a MorningStar TS60 acting as a dump load controller + Dumpload heating element
I have no misconceptions about my wind generators, I know that the best I'll get out of them is couple amps, I plan to upgrade to a proper turbine in 3-5KW range once I can afford it.
I'm looking at couple lightly used Honda generators locally to connect one to my MS4024 to charge the batteries when it's cloudy for too long
My next steps are to get breakers, lightning arrestors, gen auto-start, combiners boxers, wiring and to start the assembly.
Couple questions to which I would appreciate an answer:
- Is there a better way to connect wind generators then directly to the battery + dump load? I know about Midnite Classic and Clipper, but it's not worth it for this toy turbine.
- For my 24 Volt DC loads, do I run those from the battery bank or is the inverter involved?
- Do I need lightning arrestor for each combiner box? What makes the combiner box compatible or incompatible with the Lightning arrestor?
- How do I size the generator for this system? I've seen a lot of generator info on this forum, but not much on sizing.
- Does sizing the battery differ in any way if I'm using a forklift battery since it has thicker plates and higher charger rate?
Looking forward to getting some input.
Equipment:
Outback MX60 CC
