I agree. But how much of that 122 billion kWh came from Utah & Wyoming and how much came from Idaho, Oregon, Washington, Nevada, Montana & Colorado? There is a lot of hydro and wind power in Wash, Ore & Mont and Solar in Nev so I would have a hard time knowing how much came from each but 122 bill is a lot.
Estimating the Capacity of Solar Panel/Battery System
The whole point is CA energy policy has failed big time. Each year CA has to import more electricity. It is loosing ground and completely dependent on 9 states total to meet energy demand. Sooner or later there will be rolling Blackouts in CA because outside states will not be able to meet the demand. CA has no one to blame but themselves for letting it happen.
I do understand your point, Montana biggest fuel is coal followed by hydro and yes they have a lot of excess power to scalp CA with.MSEE, PEComment
I appreciate all the pessimistic (poorly dubbed realistic) responses. This system was NOT obtained designedless and I do take offense for that arrogance, Mr.Mike. I agree about the batteries as the Local Interstate store already warned me that could be the case but they weren't so eager to write them off. as you people. This was sold to me by a supposedly solar independent as a system who did have a design in mind which seemed reasonable back then in theory,I just never powered it on to test his wit. Yes, I am well aware of the open circuit voltages of the panels. The 290s were the original panels to work with a simple 12vdc charging system and the 250s were added in when we changed to the 24v MPPT charger. I assumed (my butt) that they would be put in series together in parallel with the other 4 (2+2 also in series) to input the new charger. Before i could test this all out (hand on the switch) I had to disassemble it after the Solar guy did his damage and disappeared after getting paid. My wife then said we're moving from Bend to here and here I am plowing thru insult to injury.
As far as living in the cloudy NW, that is my lot and non-NWers who say forget it are spoil sports at best and wouldn't probably do well as pro engineers. The do or die of my generation finds a way just like life does. Yes, the current panels probably won't charge the "gone like buffalo" batteries or new replacements so guess what, dust myself off and start up again. I think it is safe to say that just adding more panels to compensate for less Sun/day will provide a higher rate of charge for the time the Sun is out. Some balance point is there. Panels doesn't cost a Tesla car. The idea, guys is to make it work where your home is, not scoff at someone who is stuck living here and tell him to move The weather may not be good but the money at Intel is. I don't regard a one way Jose solution or quit the way to solve an electronic problem. I had hoped that this forum would have serious people to help others with reasonable answers, not a country club make sport activity. So much for DIY advice. I should ride across the street and talk to people on break at SolarWorld (as he turns his white stallion around and gallops into the sunset).
MSEE, PEComment
So, you are stuck with a system, that is what it is. Batteries are toast. I suggest cheap golf cart batteries to get it going again,
But we need screenshots of the stickers on the back of each of the panels. What all the gobblty gook letters and numbers say will be the best way to wire them all up.
You will need more than 24V coming out of your solar array into 24V MPPT CC to charge your 24V battery bank. I suggest you do some reading on this matter.Last edited by SIGP2101; 03-10-2017, 03:11 PM.Comment
Your system can produce around 6-8 kWh on sunny days, but to fully cover your 2.5 kW daily usage, you’ll need more panels and a larger battery bank. Upgrading your charger capacity is also a good idea. Electrical Estimating Services can help fine-tune these calculations for a better fit.
I closed this old post and edited out that link for Estimating servicesLast edited by SunEagle; 12-03-2024, 08:56 AM.Comment
