MPPT size help
  • idiggplants
    Well you were asking about expanding a system to allow up to 400watts so I gave you some ideas which direction to go.
    If 100watts is enough for your application then ok but you battery really should not be bigger than say 65Ah with only ~ 5.5amps of charging from that 100w panel.
    For your 100Ah battery you will need 200 watts of panels but I guess your shed won't be able to handle that much.
    So what is your daily watt hour usage and what do you want to grow into?
    hmm. might be some confusion. the kit we would be getting would be split up...
    • the cc would go onto the cabin... which is at 200w with a 100ah battery... would possibly go to 400w with 200ah battery, but that is doubtful. our power usage has been minimal for 20 years. dont plan on getting more luxurious.
    • the 100w panel would go to the shed with the pwm controller. it woudl be going on a "shot" 100ah battery, just cause we have one... if that battery dies, we could get away with a 30ah battery.
  • cabindave
    idiggplants,
    If you do want to go to 400 you could get the 40amp MPPT tracer model from Renogy. They have a good website to order direct from and are really very helpful. I have had nothing but good luck with them. With that size you could probably hit close to 800w total. I have the 40 amp controller and am very happy with it. There are comments above that say the controller of that brand cannot switch charge voltages but that is not true. They auto recognize 12 or 24 volt banks. You just hook up your battery bank before you hook up your panels. The website has a downloads tab and manuals for every product. Definitely check those out before deciding.
    There are people that are anti 100watt panels for their own reasons, but for small setups they have free shipping, and can be hard to beat. Obviously in a large setup they are often not ideal.
    Reply if you have any other questions. I had an almost identical setup to what you have now. I since went to 24v and use a 24v to 12v 700w down-converter by Pyle for lighting, radio, etc.
    I looked again, it seems it would be possible to squeeze your 400 watts in on the 20 amp model too if you needed to save $75. It would be the absolute max for the controller. To do this you would have to run the battery bank at 24 volts. The larger 40 amp controller would do the same wattage at 12 if you really wanted to do that.
    Originally posted by idiggplants
    well, the kit would be going for a shed which only requires 100w of panel. super low usage. no point in getting a 200w panel for it. none at all. and there is also no point in an mppt setup for it either.
    what settings would we need to adjust? we are talking about a $170 CC vs a $400+ CC. all the default settings on my pwm have been quite sufficient...
    its been quite a while since ive agreed with the "you get what you pay for" mantra. especially with electronics. especially when they come with 5 year warranties. in 5 years, by the time the warranty is up, i expect the tech to be out dated and a fraction of the price it is now anyways.
    those are my thoughts anyways. i dont mean to sound unappreciative with your input.
  • idiggplants
    First off purchasing 2 x 100watt low wattage panels usually cost more per watt than a single 200watt panels.
    Next if you go above a 200watt system using a PWM CC will usually waste some of that wattage so an MPPT is a better investment.
    The losses from oversizing an MPPT is minimal to what you would lose using a PWM CC so I would not sweat going with a 40A even if you only load it to 25A.
    Finally you really should check the manual of a CC to see what ability you have to adjust the settings. Even if it comes with a control panel that lets you access the setting does not mean it allows you to make the changes you want. Unfortunately the higher priced CC's also provide you more flexibility in it's setup.
    So the saying goes "you get what you pay for" and when it comes to solar pv system hardware the less you spend the lower the quality and shorter the life.
    if im not mistaken, you can get an add on display/controller to change charging voltage settings, as well as get info on how many ah have came in/out, current load draw, etc.. our existing controller has that ability, but we have never used it. is it that important?
    if they are overpriced, im definitely open to hearing where i can find a 100w panel and a 20/40a mppt charge controller for close to that price.
    so we would need the 40a mppt? is that going to be too big for 200w of panels?
  • idiggplants
    400w of PV, would produce 33A @ 12V [ Wattage/Voltage=Amps ] So there would be times that the 30A controller would be over paneled. Some models may not gracefully handle that sort of over power well. Morningstar & Midnight Solar both make good mid-sized models of MPPT controllers. Tracer may work, but I have no experience with that brand,
    IMO both of those "kits' are over priced.
    The renogy "tracer" CC is considered a true MPPT type but does not have the ability to change charging voltage settings.
    I am unfamiliar with the other CC.
    The amount of allowed input wattage for 12volt charging is usually limited to the Amp rating. So a quick calculation would be to multiply the battery voltage by the amp rating. 12v x 20amp = 240watts. So I would seriously doubt a 20Amp CC can handle 400watts charging a 12volt battery.
  • idiggplants
    here is the mppt im thinking about getting:
    or
    the existing panels and pwm controllers are all renogy and have been performing wonderfully.
  • idiggplants
    started a topic MPPT size help
    MPPT size help
    ok, so we are replacing our pwm controller on our small off grid setup. we currently have a 30a pwm controller charging a 100ah 12v battery being powered by 2x 100w panels ran in parallel.
    we are replacing the controller with an mppt for more efficiency. i would like to leave room for expansion. but i also read that mppt controllers, if oversized, are less efficient? id like to allow for 300-400w of panels. would a renogy 20a charge controller handle 400w?
    would we be better off switching the panels to series to up the voltage and lower our line loss? we currently have 10awg wires from the panels to the cc. about a 40' run.
    next question... is renogy good to go? i know it isnt morningstar, but if it gets the job done, thats all i care about. how about hqst?
