RECHARGE time!
This time, I'm going to take it to 14.1v CV and do another discharge to compare to the previous charge at 13.8v with absorb.
Charge current is 0.3C, or in my case with the 40ah battery, 12A from the adjustable supply and current allowed to drop to C/20 (2A) being conservative.
Within a very short amount of time, all cells reached 3.45v and stayed there, with a current of approx 9A during the whole part of the flat part of the charge curve.
*** NOTE *** This procedure, of hitting your cells with the manufacturer's normal standard preferred charge current, may help identify what your cells think are the voltages it needs to actually recharge to full, given enough time. Either that, or identify problems early on! The cells are telling you something.
Huh? I'll bet you bottom dollar that had this been an A123 battery bank, that if hit with a decent amount of current, the cells would actually rise to 3.5V (if you set your CV to actually go that high per cell) instead of 3.45 like most other prismatics, like Winston, CALB, GBS and other do. A123 is different.
This might become part of my PM procedure. The cells are talking, so I'm going to listen and look for deviations from this baseline of cell voltages and current during the flat part of the curve.
At the very end of charge, here is the data:
VOLTAGE UNDER CHARGE 14.1v prior to termination (max delta .027v)
Total battery voltage:
3.517v
3.544
3.521
3.537
AFTER ONE HOUR RESTing voltages: (not enough for absolute values, but enough for me to see a trend) (max delta .006v)
3.390v
3.385
3.391
3.389
It will take a few days for me to get around to a discharge test to completion.
INTERESTING NOTE:
ALL my voltages are measured with the Fluke 87V at the battery / cell terminals. I do NOT rely solely upon anything else, including that of my supply!
For instance, once the cells all reached 3.45v and stayed there during the flat part of the charge curve, (13.8v at the battery terminals) guess what was showing on my supply? 14.1v for hours! WRONG. If one went by that only, they might make some errant conclusions. Only at the very end did the voltages between the supply display and that of my Fluke match. Cabling is short and beefy too!
Moral: ALWAYS vet the accuracy or behavior of your other gear with something like a reputable voltmeter directly at the terminals. At least once. They may or may not track, depending on a variety of things and you can either compensate, calibrate, or accept the difference if you know what is *really* happening at the battery terminals.
3.517v
3.544
3.521
3.537
3.390v
3.385
3.391
3.389
INTERESTING NOTE:
