treadmill permanent magnet DC motor as generator
thanks for the info, so that means the voltage during the amp test was around 15v. so back to my idea, the motor is a 2HP motor. 1500W ?? so running off a pulley from a 2 stroke lawn mower, can i use an ordinary PWM charge controller? would the voltage output vary with the load from the batteries? -
Very few people in the world can generate that much power (.8 HP) and only for a few seconds. Most folks are more like 1/4 Hp or 200 watts.Leave a comment:
not sure what the Vdc was in the amp reading. the 10 amp i maintained for a few seconds didnt want to fry my cheap multimeter. the specs of the DC motor are 3400rpm 220Vdc 6.5 Amps. so its a 1400W motor? would the voltage output of the motor be constant with a given RPM? when i produced 10 Amps the RPM felt like about the RPM i had at about 10-20VdcLeave a comment:
You rock dude ! 10A @ 60v is 600W you are a super mega athlete.Leave a comment:
picked up a treadmill from the kerb, connected a multimeter to the motor and walking on the treadmill produces more than 60Vdc very easily. in the amp setting i could feel the load and had no trouble getting 10 amps with moderate effort. just wondering if i rigged it up to an old lawnmower what charge controller would i need to use as a 24v battery charger? i will post some pics or a video of the treadmill producing current 2mor
