I am rehabbing a Coleman Powermate 3500w Generator (new carb, fuel lines, plug, air filter, valves adjusted, etc). It's running great. 120v outlets work fine and it has idle control which is working.
There is a problem with the 240v circuit. The generator is tripping the circuit breaker with no loads attached. When I reset the 240v circuit breaker on the Genny it tries to rev up and bogs down like it is overloaded even though nothing is plugged in.
With the generator off I am getting continuity between L1 and L2 and also between L1 and neutral and L2 and neutral. Is my continuity test normal? If so, what else should I be looking for?
FYI neutral is not bonded to ground on this Generator.
Thanks for any help.
