What style of Tracker is this?
I was on my way from home to pick up some ducks in portland ontario, I got lost and they appeared while I was driving near Merrickville, Ontario. Sorry, I can't remember where I was.Comment
I stand corrected. I found that house using Google Earth, Imagery date of 5/31/14.
It is on the East side of Rd 15 about 4.5 miles north of North Augusta and about 1.25 miles South of Wolford Centre.
I am still amazed that the array could withstand any type of high wind.Comment
Fantastic. Although there must be another installation near by. As the photo I took has 4 buildings all similar, with a bunch of old farm buildings alongside. BTW when i was in google earth mode using maps. google dot ca, the array does not show up. see screen shot.You do not have permission to view this gallery.
This gallery has 1 photos.Comment
Found it finally. It does not show up in Satellite view, but in street view it does!
1627-1631 County Road 42
Delta, ON K0E 1G0
44.638307, -76.134609
Looks good from Google Earth. It looks like five buildings, each with 204 panels.You do not have permission to view this gallery.
I figured Higher-Ground Farm was really, really, pulling our leg. Usually I check the calendar for April 1 when I see someone sticking to their guns....
Unbelievable.
Maybe they are COMBO PV + Wind units and twirl while catching the solar.Comment
Well, they sometimes do things differently in the "Great White North" (Ehh ??)Comment
To answer the question in the subject line - this is a big tilted single axis tracker. Possibly the tilt aligns with the earth axis (poles) in which case it's a "Polar aligned single axis tracker"
One of the google street-view you can see the 3 spots it's attached to the roof - middle and endpoints of the roof ridge.
It makes sense that an array that big would have more than a single pivot point like the smaller tracking arrays have. Still those support columns must have some big concrete foundations.To answer the question in the subject line - this is a big tilted single axis tracker. Possibly the tilt aligns with the earth axis (poles) in which case it's a "Polar aligned single axis tracker"
My other question is that single house had quite a bit of land around it so why would they build the array on the house instead of a ground mount?Comment
The satellite imagery is from 2005 before they were built. I also found them on street view. Crazy array design.Comment
No need to remove snow from it like you would a typical ground mount?
You could say this is a ground mount that's large enough you can fit a building under it.
With the group of 5 buildings/arrays it must be a solar farm selling the power to the grid... Maybe with the long hours of summer this comes up better for pricing for power sold to the POCO(s)Comment
