2000k system only puts out 500 watt why?
  • charles2,david000k
    • Oct 2015
    • 161
    #91
    Originally posted by LETitROLL
    Somehow we just need to simplify this and get down the the basic fact of whether your panel(s) are actually defective in some way and losing efficiency that rapidly (not likely, but possible), or something else is going on. Have you (lately) unhooked the connectors right at a panel and taken a voltage reading straight from a single panel (no extra wiring, just the factory pigtail) from a meter that is trusted, and best if early on cool sunny day. There are so many things that can make them vary, including time of year, moisture in cable(s) or connections, or degredation of connections, just eliminate all that and take multiple readings over a day or 2 directly from one or more panels and I think you will get to a final answer quicker.
    Yesterday, 01:22 PM it is post #66
    I checked again to keep you all updated 33.2 to 33.6 on 6 panels and panel 7 is at 34.2 clear blue skies temp about 70F and sun almost straight up in the sky. All the panel were test by themselves disconnected from everything else reading were taken from panel mc-4 connectors . or pigtail
    I hate to do it but I might end up buying another panels just like these to set up with the rest to help get rid of all these factor it's either that or a enphase grid tie inverter but it looks like a expensive set up just to track output and still does not solve angle, humidity, extra but if the panels are junk I don't want to be stuck with another one.
    In my personal non professional opinion I think they are buying factory defect panels from SolarFennel Corp and passing them off as A grade. The big reason I feel this way is voltage drop, solder bubbles on cells, and some yellowish browning on the solder tabs under the glass inside the panels. I was told they are American made in California but when I tracked them down they are made in Korea PS6A-250
      That panel is a 60 cell panel intended for grid tie installs. It is NOT intended to charge 24 volt battery systems although they may work with some caveats. (Cool temperatures, low loss wiring.) The issue is that they will barely get the batteries to the ~2.45 volts per cell you'll need for absorb.
      That's about right for those panels. Open circuit voltage is around 38 volts at 25C, so if your panels are reaching 50C in the sunlight that's the approximate voltage you will see.
      • almac
        • 314
        #93
        why is this so difficult?
        charles my panels have the same specs as yours. grid tie 36v 250w. and they can charge a 24v system beautifully. you simply need the right CC. go fo a cheap PWM CC like mine. i used 2 x 30amp PWM CCs with 6 x 250w panels 3 each in parallel it charges my 330amp 24v bank in no time. here is a link to my cheapo off grid system. http://www.solarpaneltalk.com/showth...ff-grid-system but go to the end of the thread because i improved the setup over time
          • Oct 2015
          • 161
          #94
          So basicly just wait until the same time of year I got and set up the panels and everything should just return to normal?
          • almac
            • 314
            #95
            charles have a look at these 2 pics of my 24v system
            i get 1000w at 28v to my batteries. from this 1.5kw panel array with 2 x 30amp $40 CCs
            hope you didnt pay too much for this setup
              • Oct 2015
              • 161
              #96
              I really like the looks of the midnite solar classic lite. I think I might wait for taxes and buy one of their MPPT cc. Or one of these cheaper once like http://www.ebay.com/itm/25A-300W-MPP...-/130616352324
              But I would really like to know what the RJ phone jack is for it doesn't seem like anyone doing reviews knows what it is for? I like the reviews i've seen on it so far though for the price. That jack has to be there for some thing either for factory programing or customer monitoring but which is it.
                • Oct 2015
                • 161
                #97
                I didn't design the system I just told the seller I wanted a 2,000 watt system with the ability to add up to 6,000 watts worth of panels to later. O well I feel a little dumb now I just really dug into the inverter manual and the inverter is also a mppt charge controler.
                • almac
                  • 314
                  #98
                  that CC in the link you provided is for 12v batteries only. my 1st CC was a MPPT and it did not charge my 24v batteries . i wasted alot of $$$ and time because of this CC. i suspect your problem is your CC , you alluded to that at the begining of this thread, you suspected the CC was rubbish. you will find that your panels are fine. if the voltage and current on each individual panel checks ok then there is nothing wrong with them
                  • Raul
                    • 258
                    #99
                    I read followed your tread with interes like many others so I can learn from others mistakes . Stop buying cheap , please save your money and get a decent mppt CC. It will be the best investment , if you have done that in the first place it would of saved you the previous batteries and the spare cash for other thinks . Those panels are are good GT panels and will work wonders with a mppt CC . It dose not matter if they factory low grade rejects they still do the job for the money you paid . You want premium you pay premium . Your next requirement is a CC that takes a minimum of 150vdc and good to go . Go for cheap PWM and you will never see absorb or equalise then you will look for more batteries again.
                      • Oct 2015
                      • 161
                      #100
                      What kind of battery is a AGM glass mat technology battery? 70Ah 48PLT
                      the book said to multiply you voltage by two the symbol it give is this *2 so your 14.6v would be 29.2v
                      #1 Gel USA 14.0 13.7
                      #2 A.G.M. 1 14.1 13.4
                      #3 A.G.M.2 14.6 13.7
                      #4 Sealed lead acid 14.4 13.6
                      #5 Gel European 14.4 13.8
                      #6 Open lead acid 14.8 13.8
                      #7 Calcuim (open) 15.1 13.6
                      these are my options from the battery type selector switch it also has a (charge current control) and goes from 25%, 50%, 75%, and 100% setting with a max charging current of 85+/-5A
                      I tried my best to write it out just as it appears in the book.
                        That is why I hired a licensed professional to check the system.
                        I fully understand that! This is my big problem with the merchant. I started off with 8 panels and are now down to 7 with the rest following the same pattern as the first. volts and current drop the first panel dropped to 25 volts before they had me cut into the junction box and voided warranty just to look at some diodes.
                        Grounding Is a 30ft bare braided 4 awg wire hooked directly to each panel then run to it's own grounding rod. I actually got the wire from the power company during a past ice storm. When the power company comes through during a ice storm they don't do clean up at all most the time they just leave their waste behind and I went out and asked for what they were going to leave so all and all I got a bunch of stuff nothing really cool though like a transformer just wire and a couple of poles and what I think might be a good transformer fuse. But my ground wire is rated for pole to home service drop which here is 220V @200 amp I think. the wire is 7 or 8 aluminum strands of 12 awg wire braided around a peace of 12 awg stainless steel wire. just went and checked to be double sure the ground wire is 1/4inch thick.
                        Ok, so the panels are grounded. What about dc+ or dc- (more common)?
                          • Oct 2015
                          • 161
                          #102
                          no dc +- to earth ground.
                            Ok, so PID can't be ruled out. It is more likely to be a problem on higher voltage strings. It is mostly reversible by grounding the system, but takes some time.
                            • almac
                              • 314
                              #104
                              get flooded lead acid, not sealed lead acid. you need access to the electrolyte to know the SOC. iv saved alot of $$$ buying scrap FLA batteries. 50% of them are ok the rest i get my $$$ back since i only pay scrap value. the plates on scrap batteries are either caked in lead sulfate crystals or the plates are totally corroded and gone. if they are gone the electrolyte is black. the ones with clear electrolyte can be salvaged. apply an equalizing charge for a few days and they will come back to 100% SOC.
                              also never overload your inverter. i was using a 2000w sine wave inverter sometimes overloaded it, always relied on the overload cutoff until one day it didnt cutoff and the inverter burnt out. so now i use 2 inverters to split the loads. got a 1700w pure sine wave off ebay for $210au free delivery to run the fridge. works fine.
                                • Oct 2015
                                • 161
                                #105
                                I'm sorry what is PID?
