Enphase M250 Specs for off-grid, tips and tricks and results
yeah, no (less than half earth):
Mercury, now (at least the half of the planet facing the sun) YES, (6.6 times as much as earth)
http://nssdc.gsfc.nasa.gov/planetary...rcuryfact.htmlComment
Hi Solarddy, Syedamerali, and Everyone else.
I'm looking at the enphase M250s for use in a 1.kW RV based system. I've found this discussion very interesting. Has anyone else progressed with this islanded M250 concept recently? I'm looking at a 240VAC UPS modification to generate my "utility signal" with some form up "dump load" to deal with excess generation from the M250s.
Any update on progress/failures/tip/etc.. would be greatly appreciated.
Thank you,
-M
Why would want to use microinverters? A normal charge controller (if you have batteries) works well. If you have enough shade that you think you need microinverters, you need to stop and rethink what you are doing.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Thank you,
-MOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Thank you,
-MComment
