I have a detached garage about 100 ft away from my house in NW Ontario Canada. I currently have an extension cord (12g) running to it to power my lights (10 of 6 watt LED bulbs) and a garage door opener.
I also have a 100 watt Coleman solar panel and a dual battery charge controller (10 amp PWM from fleabay and China). I use one battery output to keep a plow truck battery charged year round...I would like to find out if its feasible to...
1- periodically (every two weeks for 10 minutes) use the welder (can't be more than 1500 watts as its 120v)
2- power the garage door opener (??? watts Chamberlin DC motor with battery backup)
3- run the lights (60 watts)
without adding a generator.
I assume I would need a battery bank fed from one of the CC outputs of sufficient capacity to run a invertor constantly to feed the door opener and supply the welder.
Is this a pipe dream or should I buy a small generator to use when welding?
