Question About Neutral-to-ground Bond
  • joeyp
    • Jul 2012
    • 56
    The user manual for the Cotek SK1500-124 24V Pure Sine Wave Inverter states:
    3-6. AC Safety Grounding:
    The AC output ground wire should go to the grounding point for your loads
    ( for example, a distribution panel ground bus ).
    3-6-1. Neutral Grounding (GFCI’S):
    3-6-1-1. 120V models:The neutral conductor of the AC output circuit
    of the Inverter is automatically connected to the safety
    ground during inverter operation. This conforms to National
    Electrical Code requirements that separately derived from AC
    sources (such as inverters and generators) which have their
    neutral conductors tied to ground in the same way as the
    neutral conductors from the utility tied to ground at the AC
    breaker panel.
    This says a neutral-to-ground bond already exists within the inverter, for the AC output side, right?
    And so I will run a ground wire from the inverter chassis to the ground bus bar in my DC panel. But should I include another bond there, between that same ground bus bar and the neutral bus bar?
    Would that make two bonds...which is bad!?...or would the two be separated, one on the DC side (breaker box) and one on the AC side (inverter)? Or does the inverter also bond on the DC side as well?
    Thanks!
  • joeyp
    • Jul 2012
    • 56
    The unit does NOT have a GFCI outlet.
      This a sort of a gray area, I don't have your manual for your transfer switch, inverter, or main electrical panel. Best advice is to have the person who installed the transfer switch, decide for you, how to manage bonding for your "Separately Derived Source". All depends if the transfer switch breaks the neutral, and where the main panel bond is.
      It's not simple, and from way over here, I can't help. Your local installer is your best bet.
      • joeyp
        • Jul 2012
        • 56
        The setup is much simpler than that. There is no transfer switch. The inverter will simply have electrical extension cords plugged into it for now.
        I just want to know if I still need the neutral-to-ground bond in the DC breaker box. The manual for the charge controller shows it.
        • joeyp
          • Jul 2012
          • 56
          I'm not sure if I'm referring to this using the correct terminology. I mean to say..."The wire connecting the DC negative bus bar to the Ground bus bar."
