Do I need a BEEFIER (shore/generator) charger, and should the Solar CC be disconnecte
  • motokrome
    • Jul 2015
    • 9
    Hi all. I'm still working on hooking up my first system, and thought I did good when I got the "BoonDocker" 60A Converter. I was just reading on "HandyBobSolar.Wordpress" and he says that "Converters" are almost useless for charging from Shore Power or Generator. Apparently that 60A at 14.6V is not really based on the condition of my battery-bank, and it's just a little boost when it's first plugged in, and just switches back to trickle-charging whenever it wants to.
    My goal was to charge my 12V / 450Ah battery-bank at 45A (can I just round that up to 50A?) as quickly as possible, so as not to waste gas and hours on the generator (when there's not enough sunshine). "HandyBobSolar.Wordpress" says that I'd have to run my BoonDocker Converter for more than 24 hours and still my battery-bank wouldn't be fully charged. I am under the impression that my BoonDocker Converter is just a fancy trickle-charger, with some "boost mode" thrown in just for hype.
    I have two basic questions:
    1. Should I get a different (automotive?) 50A charger for my rig? (if so, what would you all recommend?)
    2. Should I disconnect my Solar Charge Controller when charging my battery-bank from shore/generator with my secondary charger?? (I fear that current might feed back into the Solar Charge Controller and muck it up.)
    Looking forward to your responses, thanks.
    (Here's a copy/paste of the part of his blog that got me worried about my set-up):
    "CONVERTERS: Here is the other place that the RV industry has really let us down. Nearly all basic RV’s, whether they are trailers, fifth wheels or motor homes are equipped with something called a converter or “charger”. This mislabeled item should be called a battery maintainer, because it is designed to be plugged into shore power in an RV park 24 hours a day, which is really what the RV industry wants us to do. Converters are set to maintain the batteries at the “float” voltage, about 13.5 volts, and supply a trickle charge (2-3 amps, or 25-35 watts) to keep the batteries full, while not over charging them and boiling them dry. Because of the length and size of the wiring in most rigs, the converter typically supplies less than 13 volts to the battery. Some newer three stage converters will put out over 14 volts, but that is still too low. You cannot successfully charge batteries with a converter, because you never get the batteries up to the required 14.4 volts and hold them there long enough. Don’t pay any attention to the amp rating of the converter and don’t believe that it is a good charger just because it is labeled three stage. DO NOT WASTE YOUR MONEY UPGRADING TO A THREE STAGE CONVERTER, THINKING IT WILL BE ANY BETTER. It will put the rated amps out for a very short time after you have run the batteries down or have just plugged in and it will drop to float the second it reaches whatever set point they used, then it will taper the amps off to a trickle at about 13 volts, long before the batteries are full. Plus, if you have any solar power, the voltage it puts out will be sensed by the converter and cause it to go into trickle charge mode even sooner. I installed a new 60 amp Intellipower converter in a friend’s rig & when we started the generator I measured only 4 amps output at 13.6 volts right away. It dropped from bulk charge to float in seconds, and those batteries were not full. Does that sound like a battery charger to you? Their own spec sheet says that it drops to float when the batteries are at 90% and in my experience this is very optimistic. My solar system actually puts more amps (3.5 amps) into my batteries on a cloudy day than your average converter does, and I can’t keep my batteries charged when it is cloudy, even with that trickle charge working all day. Therefore, you can’t expect your converter to charge them, either. You are actually lucky to ever get your batteries over 80% full with a converter that is plugged in for several days unless the rig is stored and no electricity is being used. The single battery supplied on most small rigs holds about 90 amp hours. That is about 30 hours of charging from the converter, but at the same time you are still running loads and reducing the power actually going to the batteries, so we are talking days, not hours. The truth is that it takes even longer because batteries are not 100% efficient, especially when they get closer to full. In 2007 I repaired the solar system on a friend’s motor home that had been plugged in for a full month at a park and then driven to our camp for a half hour, with the engine alternator charging the batteries. He arrived with his house batteries at 12.5 volts and the hydrometer showing them about 75% charged. This is typical of rigs that are kept in RV parks & occasionally taken out to boondock. They never have fully charged batteries. Converters need to be plugged in 24 hours a day to work, not run for an hour or two with a generator."
    4 x 100W Mono Panels, MPPT40CC, MT-5 Tracer Meter
    I won't say yes, or no. It depends. I would not paint all "converters" as useless, seems like one should be built properly.
    But you do need a way to manage your system, either learning how to read the volt meter and understand and anticipate what the system is doing, or rely on a verified charge controller to manage the batteries. Solar PV systems seldom have enough daylight to actually fully charge and get to float, so a converter powered 24/7 going to float after 10 hours should be OK, if it's voltage is correct. All depends on the size of the battery bank, and how many AH you withdraw. figure 80% efficiency with lead acid, 100 watts used, 120 watts needed to replace.
