I couldn't decide whether to put this in the on grid or off grid sub forum, so let me know if this isn't in the right place. Figured the off-gridders have had to get a bit more resourceful
To get to the crux of the question, I would like to have a system where there's a battery charger on AC hooked up to the batteries 24/7, but only keep the batteries at 80%. The solar panels would be responsible for pushing the charge above 80%. Therefore, the AC wouldn't kick in until the batteries dipped down to 80%.
The smart chargers available seem to be configured to keep the batteries topped off to the brim continuously (rather than the desired 80%). Does anyone know of an existing solution/equipment or clever DIY that I can deploy to achieve this? While there is intended to be a computer running 24/7 in this shed, I would like to avoid using computer controlled relays soldered onto existing meters/chargers to program this behavior.
A tiny more background is that I have the luxury of running AC to the shed 24/7, but I want to have solar contribute to the energy source. The shed is not supposed to use much power, but even so, I've calculated that going securely off the grid will be pricey. But going mostly off the grid, where AC can kick in on those stretches of cloudy days etc is significantly cheaper.
So my thought for doing this would be to have the solar panels connected to the battery bank with the charge controller as usual, and to simultaneously have the bank connected to the AC battery charger set to keep the batteries no lower than 80%. The computer electronics/lights would also be continuously drawing from the bank through an inverter.
Any ideas?
Thank you.
Any ideas?
Thank you.
