You really do not need a BMS for 16S
Not at all, If done correctly you can parallel lead aicd. The problem with Pb aka Lead acid is most folks use 6 or 12 volt jars, rather than 2-Volt Lead Acid batteries. If you were to use two volt Pb batteries them you can parallel them exactly like you would Lithium cells. Pictures is worth a thousand words.
You parallel at the Cell Level. not string level. Example the Tesla Roadster uses 6831 18650 cells arranged 99S69P. That is 99 cells in series and 69 cells in parallel.
