I recently setup a new off-grid system designed around the Outback FP-1 system with a MATE 3 system controller.
A few weeks ago, the MATE 3 encountered a known bug and went into a boot loop...so it has been out of the picture for some time. But the rest of the system seemed to be functioning normally. Until two days ago, when the power went out 4 times, once first thing int he morning (battery level showed below 50%, and then three more times that night. Each time the power went out I reset the system, but that evening...it was quite obvious the batteries were dead. The next day I ran the generator all day to restore the batteries and I figured it was simply due to low solar exposure due to a few rainy days. The weird part was that after resetting the system, the battery level indicator showed the batteries were full again, which seemed was quite obviously incorrect.
Yesterday, I replaced the MATE 3 system controller to get more detailed information on the system and we also we had pretty good sun yesterday and today. But I noticed at the end of the day today, the battery SoC was showing and error again, and the MATE 3 is indicating a battery level of 34%...HOWEVER, the battery voltage is reported as 58V and I confirmed that with my MM. The batteries are 8x Trojan L16P-AC 6V 428Ah. All components are about 3 months old. I checked the water level in the batteries and it is good.
I'm still learning a lot about this stuff...but it seems to me that the voltage level I am observing, indicates a higher SoC that what the MATE 3 is reporting...is that a possibility? My float setting is at 52.8V, so it seems that the batteries are never going into MPPT Bulk charging, because the voltage level is too high...why is this happening?
TIA
TIA
