I'm planning a major move to Central America soon...the locals tell me I should expect greater than 800W/h/m2. There is no "grid" in the area, so off-grid solutions are my only option. The community is eco-friendly, and I DO NOT plan to supplement my solar system with a generator. If power runs out, we'll just have to get by without it. I've gone through most of the sticky information trying to figure out what the optimal system for me would be, and I think I have a plan, would you experts please evaluate me and tell me how I'm doing thus far? Thanks in advance.
The immediate problem I've identified is that the charge controllers only allow up to 60A output, which is not enough for my proposed system. So I would rather downgrade as I believe our lifestyle change will encourage lower power consumption. So my revised system would be built as follows:
I think this would provide my family and I plenty of power in our new home, the question is, have I missed any steps....and have I done my calculations correctly?
Would you suggest any revisions to my plan...and would you recommend sourcing any of the equipment from alternative stores?
My biggest concern is the battery bank seems way too big (1666Ah needed, 3690Ah planned)....but I think that is probably preferable right?
Thanks again in advance
- Based on my family's power usage over the past few years, I would need about 25Kwh per day.
- Fudge factor - 25Kwh x 1.5 = 37.5Kwh
- Sun hours in December = 11h ... solar isolation = 8.8Kwh/m2/day
- Size of Solar panel array = 37.5Kwh / 8.8h = 4.26Kw
- Battery size required = 25Kwh x 5 = 125Kwh / 48V = approx 2600Ah @ 48V
- Charge controller = 4.26Kwh / 48V = 89A (I haven't found a controller that will do this)
- Battery bank = 8 x 460Ah 6V = 3680Ah @ 48V
- Shooting for 5Kwh per day or less.
- Fudge factor - 5Kwh x 1.5 = 7.5Kwh
- Solar isolation in December = 4Kwh/m2/day
- Solar panel array = 7.5Kwh / 4h = 1875W required ... I would use fourteen 230W panels = 3220W
- Battery size required = 5Kwh x 5 = 25Kwh / 48V = approx 520Ah @ 48V
- Charge controller = 3220wh / 48V = 67A ... I would use a 150A MidNite Solar Classic 150
- Battery bank = 8 x Rolls S-530 530Ah 6V = 530Ah @ 48V
