So I read the sticky about inverters and had some responses from some of my other response. If i run a 1000w inverter for a load of 100watts it probably is not runny as efficiently as a 300w inverter would be at 100watt draw. Can you run two smaller inverters off the same battery bank to different circuits?
Example:
500watt inverter connected to lights and power sockets to be used when at the cabin
200watt inverter connected to satellite internet running 24/7
Or is this a totally stupid idea since I will be using a 1000w Pure Sine Wave inverter any way? Don't worry I can take it directly if this is a dumb idea.
Example:
