Positive voltage from PV reads -18v when connected to charge controller??
  • aaronfro
    • Feb 2014
    • 4
    Quick question:
    I have a Meanwell tn-1500-112 solar inverter/charge controller
    and when I tested the pos/neg leads coming from my panel... they read +18v
    I then connected to wires to the solar DC input of the inverter
    Places my alligator clips on the wires and my multimeter reads -18v
    Does this sound right??
    The flow of electrons is reversed when connected to the charge controller??
    I'm sure my wires are all pos to pos... neg to neg... no crossing
    Any ideas on why this is??
    Thanks in advance!
    -Aaron
    No polarity does not change. Assuming they are standard battery panels you should read about 22 volts open circuit. When connected to the controller and batteries taking charge will depend on what type of controller you have. If MPPT should be around 17 to 18 volts. If PWM about 1 volt higher than the battery.
    • aaronfro
      • Feb 2014
      • 4
      A good friend of mine (who's an electrician)... just told me earlier that when sampling the current in parallel... the polarity will "reverse". It was very overcast and I was getting +18v from the panel.... so I expect it to go even higher when sunny. I'm still trying to visualize the flow of electrons and WHY it would "reverse" as such. I have a Meanwell tn-1500 inverter/charge controller... and if the PV input wires were reversed it would recognize.
        Originally posted by aaronfro
        A good friend of mine (who's an electrician)... just told me earlier that when sampling the current in parallel... the polarity will "reverse". ....
        Your good friend is a great joker. Buy him a beer.
        Nowhere in any PV system, does the polarity of anything magically reverse.
          A good friend of mine (who's an electrician)... just told me earlier that when sampling the current in parallel....
          His license should be revoked. Do not listen to him, he does not know what he is talking about.
            • 15160
            Maybe he was thinking about the Earth's magnetic field. It reverses polarity every once in a great while.
            • aaronfro
              • Feb 2014
              • 4
              Ok I'm not trying to get y'all too excited.
              I have the manual for the inverter... that I got from a friend.
              The manual... and all the distributors for Meanwell tn-1500-122
              Don't disclose the exact pin info on the PV DC solar input for the inverter
              If you look at the manual... you will see that the pos and neg input on the inverter is labeled
              And the solar input is on top... it's a 6 pin molex connector
              When I connect the pos of the PV panel to the pos input on the inverter (and the neg respectively)
              The wires then read -18v
              Either the inverter has the solar input polarities reversed (as labeled)
              Or something else is going on that I don't quite understand
              I didn't want to hook up the panel in reverse because of obvious reasons
              And I didn't get a "reversed polarity" warning beep or light
              I'm curious to know if anyone with an offgrid system
              When tapping into the pos and neg inputs of PV into charge controller/inverter
              Have experienced the same thing??
              If Meanwell (Taiwan) has the polarity of the input different as labeled... I wouldn't be suprised
                I have wired up many inverters, charge controllers and batteries.
                You have a miss-wire somewhere if you are seeing polarity changes.
                All of mine, use individual wires to each terminal. Wire them + to a + and - to a -, and it's always worked right for me.
                Never worked with Meanwell. Maybe they mean well, but it just doesn't work out ?
                • Shockah
                  • Nov 2013
                  • 569
                  [CENTER]SunLight @ Night[/CENTER]
                  • Wy_White_Wolf
                    • Oct 2011
                    • 1179
                    I have to ask. Why are you wiring the panel to the back of the inverter?
                    It should be wired to a charge controller then to the battery.
                    WWW
                    • aaronfro
                      • Feb 2014
                      • 4
                      It's a solar inverter (has a charge controller built in)
                      • Legacy
                        • Mar 2012
                        • 57
                        According to the spec sheet from the companies site , the positive 3 terminals are on the side
                        of the plug with the rounded corners an the negative on the side with the square corners.
                        I take it you have your batteries hooked up to the DC input before you hook up the solar panels
                        to the six pin plug?
                        • Wy_White_Wolf
                          • Oct 2011
                          • 1179
                          Never seen one like that. Mind sharing the make and model number.
                          WWW
