Hi guys,
Can any one give me advice on the following. We are in South Africa and voltage is 240V.
I have read on a site, cant find it again, but they were talking about an MPPT Charge Controller not requiring fuses between the panels and the controller. Is that correct? Can anyone give me advice?
I have an installation of 8 x 250W (Vmp 30.1V and Isc 8.83A) in parallel, 25A MPPT charge controller which is integrated in a 3KVA/2.4KW 24Vdc Inverter. Between the solar panels and controller is 12A fuses on each of the panels and 4mm sq solar cable. Between the controller and battery is 100A circuit breaker and 25mm sq cable. AC cable input to the inverter/charger is 32A circuit breaker and 4mm sq cable.
The question I have is, are the fuses correctly sized? Is the cable correctly sized? Do I need to install Circuit breaker between the battery and the inverter and what size? And most importantly, is the 25A charge controller big enough for 8 x 250W panels? Does anyone have experience in installing this type of inverter/charger and if so, how would you install an extra 2 x 25A MPPT charge controllers in parallel to the one in the inverter, if it is required?
Output from the inverter to the sub-db board will be for the client.
Well, thats my problem, look forward to receiving your comments.
Philip
Philip
