I did the load calculations and found that 600 watts should meet my needs.
I have a brand new Sanyo 195W panel its output is almost 60 volts.
I can't find matching panels with that high voltage output.
I can find many that output in the mid 30 volt range.
So I thinking of hooking two of those up in series and then adding the Sanyo in parallel.
Hopefully this would balance the incoming voltage to the controller.
Am I on the right trac doing it like that or is there another way.
Controller suggestions without spending more than I need to would also be appreciated.
tks
tks
