Just be careful with the inverter. Most items like refrigerators need a pure sine wave power not a modified sine wave that you find on the cheaper inverters.
You need to first understand what your equipment draws in "watt hours" before you can really build your system. There is a device called Kill-a-watt that does a really good job giving you that information for 120volt equipment. Costs about $30 but will save you a lot more in the long run.
As for a true emergency back up power. As russ indicated the best bang for your buck is an LPG generator and a big tank. That will be able to run a lot more stuff than a small to middle sized solar panel system.
I have gone the "belt and suspenders" route. I have a couple of gasoline generators (5500 & 1800 watt), an LPG 3500 watt generator and my small (and expensive) solar generator. I tried to cover the bases by going one piece at a time but now wished I had gone the way of an 8000 watt LPG system. Live and learn (and spend).
