here is my idea: i have a good sized shed out back and i want to turn it into a temporary work shop until i can build a bigger one on a concrete slab. i dont want to run 200 ft of direct burial out there for just a few years of use. Yeah it`ll take me that long if not longer to build. so i was looking at going solar and if it works well, i would use a bigger system on the new building as well.
for the temp. shop i just need enough 110/120 volts to run a small air compressor (1/2 hp motor) a couple lights, and a drill and grinder. i would only be running the lights and compressor or drill and compressor at one time. not a whole lot of demand. i can`t find anywhere what i can actually do with a 200 watt inverter. i plan on 1 battery and adding a second one later if i need it. i just need a small space to work on things easier as my business takes up my whole 2.5 car garage. the air compressor is just for tires and a blow nozzle, it isn`t big enough for air tools. if i buy all the things i need separately it is really expensive. i need to start small. being in Florida i figure we get a ton of sun and solar should be easy to use. i found this kit in Northern tool and on amazon. but no real reviews that hit on what i want to do. any thoughts?
