Just a line to describe what I have installed. So far it seems to work. I have 4 Sunforce 15W panels wired parallel mounted on a 20 ft TV tower, feeding into a 7 Amp Sunforce Charge Controler, The Charge Controler feeds two 103amp/hour 12V Marine Deep Cell Batteries which are wired in Parallel. All I normally run are 3 - 7w CFI's (1 at a time) using a smal 75w inverter, a small 1.8 gal/min on demand water Pump (12V), and a 12V car Stereo(14-16 hrs/day).
I have stayed as long as 17 days with no issues although I did run the batteries down to 11.3V due to 6 continuous days of rain and overcast. I do have a 2900 watt generator if things get out of hand and I need to charge the batteries, but I really hate listening to a generator.
I do have two questions though: 1) I have one panel that cracked do to the wrong type of fatener used in the wrong spot - Is this interfering with the output of the other panels? and 2) If I was to charge my batteries using the genarator, which are wired parallel can I hook the charger to one battery and have both charge at the same time or should I hook the charger to the positive on one battery and the charger negitive to the negitive on the opposite battery?
Thanks for your help
