I own a hydroponic greenhouse operation (I grow lettuces, basil etc) on the Central Coast of CA. I am installing a couple of belt driven exhaust fans and want to run them off of some PV panels. The fans are 48 inches across and draw around 10.8 peak amps. I have a completely open south facing location to put them.
I was hoping to connect the fans directly to the solar panel because I only need to run the fans when the sun is out and my greenhouse begins to heat up. Correct me if I am wrong, but from what I understand is that running a fan with too little power will not harm the motor in any way, only too much power.
Is this type of system possible? I would like something to switch the fans off in case the sun is out, but it is still a cool day.
Thanks for any help!
Eric
Eric
