I would not do it because you are just robbing Peter to pay Paul.
Using SolarT example. He has a 250 watt panel with a 15 amp current limit. With say a 5 Sun hour day the panel delivers 1 Kwh to the batteries. However if he had used a 20 amp controller he would have 1.25 Kwh, so he gets short changed. I understand over sizing a panel on a MPPT stretches harvest time, but but we are only talking sun minutes, not hours. Common design practice is to over size 10% PTC rating. SolarT is at 25% robbing himself, meaning he would get substantial more harvest if he used a 20 amp controller.
250 watt panel with Morningstar SunSaver MPPT 15 AMP controller
Morningstar’s TriStar MPPT™ & SunSaver MPPT controllers are the only controllers that will always limit the
output current regardless of input power levels. Morningstar’s patented TrakStar Technology is capable of
limiting the output current, while other manufacturers’ MPPT controllers will operate above their maximum
current ratings at higher power levels.
Morningstar’s MPPT controllers can operate with an oversized array that is several times larger than the
maximum Nominal Solar PV ratings, while still limiting the maximum battery current to the controller’s
maximum current rating. Many other MPPT controllers on the market cannot react quickly enough for fast
changes in solar conditions. Even at the published maximum power levels, these controllers are known to exceed
their maximum output current ratings and can trip the overcurrent protection fault shutting off the controller
during high power conditions.Leave a comment:
Some of the benefits in exceeding the nominal wattage ratings of an MPPT controller include:
• Effect of maximum charging power limit of a Morningstar TrakStar MPPT controller on an oversized
array:
o Better production early and late in the day.
o Operates at maximum power rating getting full charging potential of MPPT controller more
often.
o Better production during low solar insolation periods (cloudy weather).
o Limits the maximum charging current.
• Viable reasons for using an array rated for a wattage greater than the controller maximum:
o Daily maximum power levels may typically be lower than STC rated power of the solar modules.
Tilt, azimuth angle, time of day or year, weather, climate, dust, pollution and other
factors reduce output power of the array leaving some unused controller capacity.
o Energy harvesting during lower power production periods (cloudy weather) is often more
valued than during times when the array can operate at full power (sunny weather).
o Ability to use larger array sizes for more options to better match strings for the array.
o Using fewer, but high power, modules instead of several smaller ones is more cost effective.
o The availability and lower cost of 60 cell modules (Vmp~30V) from the Grid connected solar
market.
o More consistent levels of charging current (running controller at maximum levels more
consistently).
ah, no rush for me. I'm happy with my current 580W panels, 200Ah Batt. system for now but always thinking, always planning out my next project.
A question for the experts here... Do all MPPTs have oversize capability or is this only with the Trackstar system? Sure would be nice if CCs were rated to match available battery Ah (or even better, adjustable amp output)... like a TS-MPPT-25 for a 200-225Ah Batt. ...which morningstar doesn't sell.
edit: oh, poorly worded... Trackstar is patented but.. just what is the circuit that limits amperage? Does anyone make an 'add on' to do the job?Leave a comment:
After refining my search terms I found the answer from Morningstar. Not only is it acceptable to have a higher wattage input from the array than the specs call for Morningstar recommends doing so. An informative read.
Q5. Can I use a 240 Watt (60 Cell / Vmp 30V) PV module with a SunSaver MPPT™
controller?
Yes. Even though the SunSaver MPPT™ controller in a 12V system is nominally rated for a 200W PV array, you
can use a larger PV module e.g. a 240W PV module.
• For 12V systems the SunSaver MPPT controller is an acceptable option due to its ability to convert the
module voltage down and charge a 12V battery very effectively.
and more .......
array:
often.
market.
consistently).Leave a comment:
I wonder if it really is 25% more. Isn't there a derating that will reduce the current before it reaches the controller? And thanks for your replies.Leave a comment:
Do you have the panel already. If not use a 200 watt panel.Leave a comment:
Is it hard on the controller to have more watts coming into to it than it was rated for or can the controller handle it?
I don't know if there are any good quality ones in 25-30 amp range.I don't really need the full 20 amps and it looks like a pretty big price jump to go to the next level of 45 amp MPPT controller.Leave a comment:
Problem is the maximum panel input for the Sunsaver MPPT is 200 watts with 12 volt battery, and 400 watts @ 24 volt battery. At 250 watts you crossed the line to a 20 amp controller. At 250 watts with MPPT controller is 19 to 20 ampsLeave a comment:
Hi,
Trying to keep costs down could a guy get away with the configuration of a 250 watt panel using a Morningstar SunSaver MPPT 15 AMP controller (model SS-MPPT-15L)?
The battery bank is two Trojan T105s. 3-4 hours charging at 15 AMPS would be plenty for my needs.
Thanks.
