This is the first time that I will be using a MPPT cc and I just have a few questions.
I read awhile ago on a post that it is best to use matching solar panels with your MPPT, and that mismatched ones would cause some inefficiency (cant find that post now
I have a 230W panel, and would like to add more solar panels. The problem comes in that I cannot get that exact 230W panel. I have looked around and I can get a 215W or a 265W solar panel (those were the closest I can find at the time). The system will be run as a 48V (already have 2x230W panels, both in series for nominal 48V).
So...my questions...
1) I am geting a 20A MPPT (150voc) cc, and if I get the 2 new panels (either the 215W or 265W @34.4V), can I connect it to the existing panels (in parallel?)?
2) Will the cc battle to find the optimum power point? Or will it be fine, just not as efficient as having all the panels exactly the same?
3) If there will be inefficiency, will it be alot, or really negligible?
If I remember correctly, the post said that you could use other solar panels, so long as the current/voltage specs were within 5%. Is that correct?
Thanks!
Thanks!
