Hello,
I have a Morningstar ProStar 30 Charge Controller ( B002MQWXB4) that I will be installing between a Kyocera 140 Watt Panel (KD140GX-LPU) and 2 - 100AH 12 Volt Solar Batteries ( Canadian Tire # 11-1879-8) on my off-grid cabin near Sturgeon Falls, Ontario, Canada.
I understand the solar panel connection and the battery connection but I do not understand the load connection on the ProStar charge controller. I have a Blue Sea Systems 5026 Blade Fuse Block that I will connect to my batteries and use as a 12 Volt fuse box to run my 12 Volt lighting system and 12 Volt water pump for my shower.
What are the Load connections for?? What do I connect there?
Thank very much for any help you can give me,
Doug
Doug
