Indolence is a much bigger problem with Nickel Iron Batteries
than any technical problem.
It's no secret that Mr. Thomas Edison had things to say as does
Changhong Batteries in China today.
Do people listen?
A few examples.
Changhong gives the best, most concise, education about water consumption
a person could ask for.
Changhong warns you about the tragedy that will happen if you listen to some rogue,
jive salesman and also shows you the thousands of cycles that are possible
If you treat their product with care and respect.
How often you need to check the electrolyte for carbonates and other impurities
is based on how the batteries are being used according to the latest
NiFe Operators and Maintenence manual.
Saying your Nickel Iron Battery Internal Resistance problems are found mostly in the
Top Half of capacity is just working against yourself according to
Mighty 'Changhong and The Electric Indian'
Their NiFe Batteries were not designed to be run in a run-down
fashion in any way. Internal Resistance gets 4 times higher at 90% DOD
than it is at 50% DOD.
It goes on and on.
Another big problem is some people like to attack but can't seem to
find any way to attack the education getting Laid out on the peoples.
Let's do another Internet First by Old Bill and see if anyone can
Attack da man based on this hard data.
By (or before) 1915 Mr. Edison seems to have had enough with
the NiFe electrolyte.
He started to recommend that people just begin to
use a simple Battery Hydrometer on their
Edison Nickel Iron Cells starting around 300 cycles to determine when it is
necessary to empty the old solution out and put in new.
Plain and simple. NO minced words.
Why did we need 100 years for dis revelation ?
Bill Blake
Do people listen?
A few examples.
It goes on and on.
Bill Blake
