Are you kidding me? I thought everyone knew how to do that.
Hmm, no I have no idea what it even means, But maybe I should just get some solar panels that can charge a AA fully and then in time add to the circuit. but your right, it seems to be going around in circles lol.
Ok, back to the original post then.
I think I will just make the charger with only a diode and add to the circuit when and if I think I have to.
My diodes should be here soon and they are 1N5817 1A 20V Schottky low forward v drop.
and I see this solar panel, specs below
Power: 0.6W
Voltage: 2V 300mAh
Material:Polycrystalline
Weight:21g
from what ive learned I think this will work.
I will do some test and see what the values are, so I know the tolerances before I kill any batteries.
if you don't see anything wrong with the above, then that's what I will do.
I use to watch the young ones also
I'm more like Vivian than Neil lol
Power: 0.6W
Voltage: 2V 300mAh
Weight:21g
