Hi,
Here's Sunrise/Sunset for the rest of summer above
Yeah my record so far is close to 27kWh - I have the excess once my batteries are mostly full going into running my hot water cylinder element (3kW) which is 300litres, previous to this our average was much less even on a sunny day because we just didnt use what was available.
20kWh is only 6.5hrs sunshine at 3kw average - we get many more hours than that in summer.
We have sunrise 5am and sunset 9pm .... we get the sunshine hours even if the edges are at some strange angle and get only 400-500W incoming for the first few and last few hours
Of course we are in the summer months when I get these sorts of numbers - on a fine or only partly cloudy day. My regulator is feeding me these numbers, not my inverter, but there will be 1-2kwatt hours difference between these two which would be loss over the day.
On a fine day (mid summer) by the time I wake up and have breakfast at 7:15am we have already collected 500wh - Winter I have had breakfast and driven to work by the time the sun comes up, so big difference between the two.
So on the 15th Nov the total kWh counter was 5439kWh and on the 13th Dec it was 6010kWh so for those 28 days it averaged 20kwh for example.
Real numbers from my Morningstar TS-MPPT-60 (yes that's a max of 3200W full sun) - I over rated my array to collect more on cloudy days.
Rember we are quite south here - and in summer the sun sets say 8:30pm we have far more than 180 degrees of sun movement mid year (looks close to 240 degrees) but it bites in winter (probably only about 100 degrees) - the max we got mid winter was approx 13kWh on a fine sunny day.
This is all aside - we use LiFePO4 which is what the thread was about.
Hi,
