situation:
- 4S lifepo battery 100ah each cell, connected in serie=13.6v battery
- 1 cell is semi/dead, holding voltage, but lost capacity to 20ah, probably overcharged before... it can be charged and discharged, but results in unbalanced battery pack and whole pack is therefore limited to 20ah...
possible solutions:
A: adding another 20ah cells in parallel with the broken-one, which means 5x20ah cell= 100ah and connecting this parallel pack to the serie with 3 remaining still good 100ah cells. of course, before paralleling them they need to be charged same SOC, voltage and balanced top or bottom... then vice versa with remaining 3 old cells...
B: removing the wrong cell and replacing with new cells connected in parallel, but as near as possible to actual real capacity of remaining 3 old cells. which means, lets say the 3 good old cells are aged and they are no more 100ah, but lets say 60ah of real capacity. so the 4th cell to be added to the serie pack should be built from smaller cells connected in parallel to reach the real 60ah capacity. of course again, first charged, then balanced and then connected together...
C: replacing the wrong cell with the bigger one, for example 110ah
pls consider these 3 possibilities and lets discuss which solution will be best technically, which economically and/or which practically pros and cons welcomed
possible solutions:
