Measuring capacity
  • GeorgeF
    • Nov 2018
    • 277
    Measuring capacity
    According to IEC 61960-4:2020
    The cell or battery shall be discharged, in an ambient temperature of 20 °C ± 5 °C, at a "constant current" to the end-of-discharge voltage specified by the manufacturer.
    If I see official specs of lithium 18650 they measure as IEC describes (see atachment)​​​​​​.
    Cheap charger/testers measure capacity by discharging till a certain voltage , eg cut-off @ 2.8v not adjustable.
    Can I assume (tester)tools that not measure till the "end of voltage" specified by the manufacturer, the method of testing capacity is then "invalid" ?
  • jasonl549
    • Nov 2012
    • 19
    Correct. Many manufacturers set their "end of voltage" setting differently so that they can achieve the cycle life count and durability that they want. They also can play games with the C rate of the charging and discharging process to inflate their numbers.
    From what I have seen, and I have investigated around a dozen Chinese manufacturers and American "manufacturers", most manufacturers have slight differences in their rating process. So if you use a generic battery tester to measure capacity it may be off of their rating, but both ratings may be correct as tested.
    • BroncoLera
      • Jun 2021
      • 18
      To cope with that situation,
      I try really hard to only buy batteries that have a good following and a good reputation......
      Or...have a good and free return policy.
      If those things are absent I usually abstain.
      Recently I took a chance on a 120Ah battery pack advertised on Amazon.
      The battery tested out to 124Ah using MY testing method which is more stringent and less forgiving than most manufacturers.
      But I made sure it had a return period just in case.
