I would not be surprised to find out that some of the more expensive drop-in lithium batteries can do that. My BMS has a couple of temp sensors but I have never checked to see if it can control the charge ready signal with a temperature low point. That is probably not a difficult thing to do with a couple of redundant thermostats and some relays on the charge ready control line.
LIfepo4 charging in winter.
I would not be surprised to find out that some of the more expensive drop-in lithium batteries can do that. My BMS has a couple of temp sensors but I have never checked to see if it can control the charge ready signal with a temperature low point. That is probably not a difficult thing to do with a couple of redundant thermostats and some relays on the charge ready control line.Last edited by somawheels; 08-21-2019, 06:16 PM.Comment
Oh no they don't do that. LOL They sell you a nice package with a bow on it. Actually the bow is the guarantee and the software that makes if plug and play. The prices I have seen for those drop batteries is USA$1000 per kWh. You can buy the components for probably $500 per kWh.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
The shortcomings of Lead Acid batteries have been well know for 70+ years. The shortcomings of poor Li installations, improper BMS choice, not matching battery to BMS to charge source to load, just keep multiplying. A well engineered LFP system (not only the battery, but the whole system) is pretty decent but you still have hazards below 40F / 5C and if it does light off, you have some very toxic fumes to worry about.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You were mislead. LFP batteries are the safest of the Li family. They are not as safe as lead acid. It seems every month, a new way for Li batteries to fail, appears.
The shortcomings of Lead Acid batteries have been well know for 70+ years. The shortcomings of poor Li installations, improper BMS choice, not matching battery to BMS to charge source to load, just keep multiplying. A well engineered LFP system (not only the battery, but the whole system) is pretty decent but you still have hazards below 40F / 5C and if it does light off, you have some very toxic fumes to worry about.Last edited by somawheels; 08-22-2019, 02:07 PM.Comment
Victron have the new edition (black case) see on they're website, with bms integrated.
Also another alternative to that, is ultra max monolit blocks of 12v also with bms integrated. This is what I chose for my campervan. A 12v 200ah lifepo4.
Another alternative, is winston cells with bms, you can find them in EU for less than 400 quid per kWh.
I have a friend off grid, that charges Nissan Leaf bank kept in a unheated garage with minus 15-20C outside.
HI Lifepo4,
Not sure if this helps but we just installed a BYD Li Ion battery with our Arrays as a stand alone system in an area which reaches up to -9deg c over night. Overall the performance of the battery has been excellent but if the temp drops to far for to long (usually 2 days) causing the core of the battery to become to cold the battery management system limits the inverters keeping the battery to about 55% in order to protect it. We found that if the battery does become limited by the management system simply heating up the area around the battery fixed the issue and ensured the battery charges to properly.
