Hey Guys,
Sorry for the long post but wanted to be clear in what I was trying to do.
I built a small 2 panel (2x265w) system going to an mppt tracer 40amp controller then to a 12V AGm 235amh battery which then connects to a 12 V 3000w inverter. I had no idea what I was doing with the battery but I guess im one of those dummies who likes to learn by trial and error. I ran the battery down a number of times to 10.5v as that is what the inverter shut off was and I thought it was safe to do so....yes I know now
So I have recently bought an lithium battery 12v and 400amp\h. As this chemistry is new to me I wanted to ensure I was charging this saftly and not kill it like my last AGM. I am looking for max lifespan so I understand I should charge to 13.8-14.0V and only discharge to 12.7. Is that correct? I am not really worreid about running out of load as I do have an automatic transfer switch which will flip my load to street power if my battery gets low. So would it be fine to just bounce the battery from say 13.-13.8? If it falls to 12.9 it will flip to street power and not bring the load back to solar until say the battery hits 13.8? Hope I got that right.
One other thing in my charge controller there are settings for charging. I cant find any good info from the controller to explain what these are other then it says to contact the battery manfuc. The new battery is from amazon and the Chinese company has not been very helpful in recommending what I should be using.
Below are the current parameters in question and what I am guessing I should be using with my new battery.
Over Volt Disc--14.8 New should be 14.0?
Charge Limit---14.4 New should be 13.8?
Over Volt Rec--14.4 new should be 13.9?
Equal charge--14.3 New should be ??
boost charge 14.2 New should be 13.7?
Float charge 13.6 New should be 13.6
Boost Rec 13.0 New should be 12.8?
Low Volt rec 12.6 New should be 12.7?
undervolt rec 12.2 New should be 12.7?
undervolt warn New should be 12.6
Low Volt disc 11.1 newshould be 12.5
discharge limit 10.6 new should be 12.5
Equalize time 120 Dont think I need this do I ?
boost time 120 Dont think I need this do i
Sorry if that is too long winded and thanks for any feedback.
