I exposed you guys to my challenge of how to utilise my large stock of A123 LiPo modules back in November 2018
It led to this interesting topic with lot's of good information. "Lithium-ion multiple batteries on parallel - same challenge as Lead Acid or not", the first topic I made on these batteries are here: A123 Fisker Karma Battery module - 7 cells with built in BMS
After surviving the winter in cold Norway using my ageing AGM 2V 1100Ah cells in a 24V configuration (Discussed here: AGM) They still serve me well, with acceptable performance but I want more storage capacity. I have 9 x 300 watt solar panels and daily power production does reach 15 Kwh if I'm able to utilise it.
Norway has become an EV country, I have 2 of them and no fossile fuel burner any longer. It would like to be able to charge my car from a 50Kwh battery that has been charge from the sun during the week when I am not at my cabin.
So much for the introduction - here is the challenge
These A123 cells appear to be very well built, with a fuse on each cell. But they are unfortunate in a 7s3p configuration, and after the discussion back in November I have concluded that I have to reconfigure them if I am going to be able to use them. The modules are built with 20Ah prismatic pouch cells where each 3p is "flipped" and laser welded together. On each welding point 6 pouch cell tab's are welded together. The laser welding to the pouch tab's are welded for life an not possible to undo. The same is true for the A123 cell modules. They are very sturdy built, the prismatic cells are glued together with steel heat conductors, and held together by steel ribbons.
This leaves me with one option. Separating the series connection of the 3p packs and rewiring the hole module in a 7s x 3s = 21s configuration making each A123 module a 3.3V 420Ah (21 x 20Ah). A good module for making a 24V or even a 48V large LiPo battery of 40 cells in a 5p8s design of more than 50Kwh. Each of the 40 cells (the old modules) with a proper BMS solution.
The big question is how to connect these 3p modules wich are already laser welded together in a nice an profession way. Spotwelding, connect them mechanically with nuts and bolt (they would have to be tiny), soldering or by any other means.
Your views gentlemen is highly appreciated
