Here is another newbie question: When I charge my battery using the iMax B6AC, I noticed the current keep on dropping when the battery is close to full, I set it to 1A, but then see it dropped to 0.8, 0.5 eventually around 0.1A then the charge stopped.
My question is: Is the done intentionally by the iMax? So I imagine the charger will detect the battery voltage, and reduce the current when the battery is close to full. In this case the charger must be pretty smart.
Or, is this just the nature of the charging process? So the current just naturally drops lower and lower when the battery voltage raises? In this case the charger is pretty dumb?
