Electriccarpartscompany.com sells this brand of LiFePO4 aluminum encased prismatic cells. I can't find any info on the web about them. Has anyone had any experience with them?
Bright Star Aluminum Encased Battery LiFePO4
I have a pack made of similar aluminum-encased cells from a different factory. They are working great, after I filtered out a couple of bad ones through testing. -
Can i connect 2 seperate battery banks, own controller, and own panel array to a switch 3way plus off.
Be VERY careful with the aluminum casing. If any of your infrastructure wiring makes a connection to the case, you may have an instant ground and possible very unsafe condition, unlike the plastic-cased cells.
Some have been known to install insulating spacers around the cells and inside any sort of box enclosure.
