I'm top-balancing my pack of 20x, 200ah LFP prismatics to 3.5VPC. The pack is built in 5p4s configuration for a 12V pack at 1000ah, but of course i have all the bus bars off for the balancing. I'm using the Revolectrix GT1200...similar to a pL8 but with fewer features. The pack has been in service for 9 months. I had been monitoring cell voltages manually and realized one of the parallel banks was running higher than the others, that's when i began to understand i had not correctly balanced in the first place. Yes, vampire boards were (briefly) involved...they are gone now...please no lecturing on how dumb i was. I'm just trying to make the best of things now.
I first wired the cells in parallel and charged with 3.5V, then rested them for several days (scheduling issue, not procedural). Then i made a second pass, charging each cell individually. Charge voltage was 3.6; max current 40a and cutoff current was C/20 (too low; i failed to update a setting). I'm checking behind the GT1200 with my Amprobe 560 for voltage measurements and the two readings agree well. I plan to make a third pass, using the discharge feature on the cells that are coming in too high if necessary.
The rested OCV for all the cells before individual charging ranged from 3.315 to 3.541. After my second pass, the OCV (after 9 hours resting) ranged from 3.415 to 3.565...except for cell #5, which remained at 3.358. #5 had started out at 3.316 - almost the lowest of the pack. This would not bother me too much except: While no other single cell took more than 15 minutes to complete its individual charge, #5 took 3.5 hours. I did not log the Ah each cell accepted but evidently #5 took a lot more than the rest.
None of my other observations indicate any special trouble with #5 except the sheer number of Ah it accepted without breaking 3.4V. I'm trying to decide if this indicates an actual concern, or if it falls within normal (albeit kinda unlikely) variation. With the flatness of the charge curve, i suppose it could simply have been far more discharged than the others? I'd be grateful for insight or advice, thanks.
