hello,
after years of leadaciding ive got my first lifepo4 battery
as i understood the simplified lifepo4 charging thread by pnjunction, i decided for starting with no balancer version. instead of adding such a single point of failures a decided to stay with my battery in the safe interval of 30-80% SOC. i also believe full time balancer would in better case mask the real problem, in worst case in paradox destroy the battery by pushing it on the edge of the black-hole where one bad step...
anyway, i do not consider a balancer to be an enemy, just want to use it periodicaly after certain amount of cycles by HAND to balance potentialy unbalanced cells, what should maybe even not happen if SOC will really remain between lets say 30-80%, as planned...
my battery is winston 90ah 12v, so i relay on relative quality of the manufacture with combination of controller settings (epever 3210 30a mppt/270wp 36v panel). for the very beggining i plan to set them to following, conservative values(export/import file):
BatType: 1
BatCap: 90 -ah
TempComp: 0
OVCutOff: 14.00
ChargLmt: 13.85
OVRcv: 13.87
EquilV: 13.80
RaisV: 13.75 - boost, CV phase
FloCharg: 13.65 - float charging phase - was thinking about disabling it, but didnt find a way how, so set it on the lover voltage as lesser evil...
RaisRcv: 13.20
LVRcv: 12.85
WarnRcv: 12.84
LVWarn: 12.83
LVCutOff: 12.80
DischaLmt: 12.79
RatedLv: 1
EquilDur: 0
RaisDur: 10 - boost, CV phase duration in minutes
BatDisch: 30 - SOC% based charging program upper and lower limits. i didnt find any info how it really works in details...
BatCharg: 80
ChargMode: 0 - means charging based on voltage limits, not on SOC%
if you have any comments or hints about the settings, please post. every good idea welcomed
at the end finally to the point question - what happens, when battery reaches charging limit value of 13.85v and controller will cut of any charging state? where will go all the current and voltage from the solar panel until it reaches "over voltage cuttoff" value of 14.00v, which should turn of controller, so in fact everything - pv, battery, charging and load...?? will it reach that 14.00 value? what is mentioned with 14.00v? where, on battery, or solar, or mppt algorithm?
simply, by other words: what happens between OVCutOff: 14.00 and ChargLmt: 13.85 values?
BatType: 1
BatCap: 90 -ah
TempComp: 0
OVCutOff: 14.00
ChargLmt: 13.85
OVRcv: 13.87
EquilV: 13.80
RaisRcv: 13.20
LVRcv: 12.85
WarnRcv: 12.84
LVWarn: 12.83
LVCutOff: 12.80
DischaLmt: 12.79
RatedLv: 1
EquilDur: 0
BatCharg: 80
