there's a difference- other 'dangerous' things on board of your RV probably passed certain certification before you bought them. That would mean they have history of things going wrong and those certifications reflecting this. You creating LFP bank yourself and I simply wish you to avoid learning one or two small details the hard way. I have no doubt you know what you're doing electrically but safety is different kind of expertise often learned off failed designs.
In abstract sense- yes, AC bleeding. What I meant is inverter feeding AC loads would consume energy according to sine wave on the load side. It would cause equivalent unipolar sine wave on DC side in the consumed current as the voltage would remain relatively constant.
Depending how big that AC component on top of DC component of the current going through shunt is it could be ignored for the purposes of coulomb counting or not. If you could hook up scope parallel to the shunt you'd see this right away.
