Hello guys, have been reading upon the topics around here a lot and most of the answers I found last few years made me conclude I needed even more reading. However I have learned a lot reading here (and elsewhere). So thank you guys for sharing all your info.
I have a very basic question about a BMS (probably not needed for now but I got a question on which I can't clearly find the answer and the mind gets angry when it does not get it). I'm not going to put anything in reality right away but I am thinking out stuff and my info got stuck somewhere and I simply need to understand. I know I need tons more of knowledge but this one bothers me.
let's say we take a simplified battery made up of 4 series packs each containing 5 cells in parallel.
If I understand correctly, the usage of a bms is to make sure the series packs don't get out of balance to much in relation to the other packs, let's assume pack 4 has a lower voltage after charing, I have the following questions
1. a bms works by lowering the highest packs to the voltage of the lowest pack, when evened out it starts charing the battery up again,... If I assume correctly my follow up question is, If by default the 4th pack is lower, how does the bms help? doesn't this process repeat itself each recharge cyle?
2. what if 1 cell in pack 4 gets bad (and thus drags down the pack) if I understand the working correclty the bms does not help here itself at all, basically trying to compensate the pack voltage but if a cell is very bad this is a process with only disadvantages (giving unnecessary discharge and cycles to the other packs)
3. lowering the voltage in the other "good" packs to the voltage of the bad pack and raising the voltage again seems to me like a very energy inefficient method als also influencing life of the better packs.
I hope it is possible for you guys to answer this in a way I can get my mind around it. Nothing I have been reading and watching really answers these questions (or i missed it).
ps I tried the search function but it did not yield sufficient results, hope I didn't overlook a thread containing the clue. I know I still need a lot of eduction before going to real world mode, but learning starts somewhere
Thanks for your time
Bert
Bert
